It's marketing driven, the advertising agencies did a survey and asked Joe Public what "Four Wheel Drive" meant? Joe Public said big, heavy, gas guzzling waggon that can go off road but hardly ever does.
This is not what Audi/Subaru/VW/Porsche wanted to hear. The advertising agencies invented "All Wheel Drive" to distinguish their cars that drive on the road, from the "Four Wheel Drive" that bashes bushes.
Nissan made GTR's to win in Group A and they did, so they were banned.
Audi copied with the Quattro in SuperTouring and they won too, so they were banned.
Now we are stuck with Commondoors and Foulcans.
The lower spec models (GTS-T' date=' GT-T) are all RWD.
Except the GTS-4 :)
BTW, is there any difference between the (R32) GTS-4 AWD setup and the GTR?[/quote']
Gearbox is slightly weaker..
I hate the whole AWD - 4WD argument.
Go and try and talk about it on an American forums.. they will try and chew your head off if you call a WRX 4WD..
I doesn't matter to me, if it has 4 Wheels driving, it's 4WD! :D
I think SK hit the nail on the head... it's a marketing "lets change the name around to fool some people" crap..
Hahahaha guys, this is what i've learned
AWD - all wheel drive means all 4 wheels moving all the time
4WD - You can choose to be 2WD or 4WD, u noticed that those REAL 4WD vehicles like Landrover or Pajero has another gear that allows you to engaged from 2WD to 4WD.
FWD/RWD - don't need to explain that.
Just my 2 cents
I doesn't matter to me, if it has 4 Wheels driving, it's 4WD! :P
AWD and 4WD
AWD esentially has its power delivered variably between the front and the read (via diff, torque spliter, viscous coupling, whatever) if 1 wheel has no traction then the car will slip.
4WD is locked (ie equal power delivered to the rear/forward and its locked) so you have to have 1 rear wheel and 1 front wheel spinning before you start to slip.
this asumes no LSD in the above setups
GT-R's are closer to a 4WD system than a AWD
note some AWD's have a lock for the central diff basicaly turning them into a 4WD
Go for a ride in a GTR and then a WRX.
Ones got both the advatage of both rear wheel drive and front wheel drive and the rexy is locked 4wd :)
You can disconect your gtr to make it rwd which can be handy for what ever reason :). - Take out front drive shaft (5min + 4bolts)
Jun
from carpoint...............
"4WD demystified
The term four-wheel drive (4WD) doesn't make all 4WD systems the same. In fact, there's a huge variation in features and design of what seems a simple principle - getting power to four wheels. Here's a simple, postage stamp description of what '4WD' is…
Part-time 4WD
Rear-wheel drive only for dry, paved surfaces while the driver manually selects 4WD via electronic activation (a switch on the dash), or by the transfer lever on the floor. When 4WD is engaged, the transfer case locks in so power is split equally between front and rear wheel sets.
Advantages: Simplicity and less wear and tear on mechanical components, and slightly lower fuel consumption in 2WD mode.
Disadvantages: 4WD can be used only on slippery surfaces (such as dirt or gravel roads, or very wet paved roads) or transfer case damage can occur.
Full-time 4WD
Keeps all four wheels at the ready to receive power at all times. In extreme conditions you can be stuck with one wheel spinning, so most have other traction aids, from a simple locking centre diff (which makes the system effectively part-time), to electronic traction control.
Advantages: Gives 4WD grip in all but the slipperiest situations, no levers or buttons to flick, until it gets really slippery.
Disadvantages: Isn't truly 4WD on low traction surfaces when left to its own devices (unless traction control or locking/limited slip diffs are also fitted).
Selectable 4WD
A full-time 4WD system that you can choose to drive in either 2WD, like a part-time 4WD, or full-time 4WD on paved surfaces.
Advantages: Best of both worlds.
Disadvantages: Complex system.
On-demand 4WD
Takes the best of part-time and full-time systems and attempts to combine them in a foolproof, user-friendly system. No 4WD expertise is required. Basically, the car runs in two-wheel drive until the system (which can be electronic, hydraulic or a combination of both) senses that one axle is spinning faster than the other and shuttles power to the 'dead' axle.
Advantages: Less drag on components, potentially allowing better performance and economy than full-time; user-friendly.
Disadvantages: Some systems are slow to engage 4WD and are complex (read: expensive) should it all go wrong."
I argue that AWD and 4WD are different!
Jensen FF inteceptor CONSTANT AWD
Range Rover CONSTANT AWD
GXL + Cruisers CONSTANT AWD
= constant power transmitted to front and rear
GTR 4WD
Prior to GU Patrol 4WD
Rav4 4WD
Pathfinder 4WD
= selectable 2WD/4WD (either manual/electronic)
it's not that hard, like everything - you should not beleive everything you read / hear. You should always do your own research.
So DAN00H the Lancer Evolution 8 is 4WD and the Lancer Evolution 8 RS is AWD?
It is a rediculous situation to make such a distinction.
Nobody has quoted any sources apart from The_Paladin and nothing I can find is even remotely convincing that there is a specific or technical distinction between them.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
