Hi, I just bought my GTS RB 25 Turbo model 1995 Automatic, My problem is that when the speed reach 180 Km and if I try to exceed 185 Km the engine refuse to drive faster!? some of my friends told me that there is a speed limiter fitted in the car but I dont know how to remove it?! one of my friends car can speed up to 250 Km and no speed limiter?! :P
https://www.sau.com.au/forums/topic/54051-speed-limiter-cutoff/
If you cut the speed sensor wire though, doesn't it effect the Hicas, which has some component that is speed sensitive? There are devices out there that will alter the speed cut signal. Apexi RSM will do it, orange or blue screen versions. So second hand they wouldn't cost a lot, brand new they are only $450 NZ. This allows you to change or turn off your rev limiter, and change or turn off your speed cut. I got rid of my speed cut but slightly lowered my rev limit to further protect my engine just in case. Cool gadget, has the addedfeatures if you go that way, or timing stats, (and on the blue screen versions) the added G sensor allows you to measure the cornering G's your car goes through.
If you do intend to cut the wire 53, check, do lots of homework, and check again. LAst thing you want is the rear of your car to be activating the hicas randomly while pulling in exess of 190km/h.
  • 4 weeks later...
It is definately wire 53 on the R32. I cut it and put it on a switch. The reason for this is it prevents you from exiting Hicas Diagnostic mode when the wire is cut. This is the only thing it effects on the manual. The automatic may be a different story. Comes in handy when you blow away an STi and he thinks he's gonna catch up...hmm I don't think so.
It should be a green wire with a yellow trace. Well it is on the 32 anyway. Good luck with the life ending.
]']same on the R32?
put in on a switch ? turn it on and off then u get a speed limiter that comes on and off?
WHAT DID I JUST SAY?
  • 4 weeks later...
  • 3 months later...
"your going over 180km/h without major mod's(stock ECU), hummm that would take some road, i wish i knew where the was a road like that around here, if you can drive for 100M without hitting a pot hole your doing well."
Not really, i've got a r33 gts-t with just an exhaust and bov and took it on the track. 180km is only about 5 grand in 3rd and it doenst take long at all to reach it. It's very easy to do.
  • 3 weeks later...
i hit 180 almost everynite i got 2 work on the motorway,blacktown 2 silverwater, 11minutes is my best,but thats just squirtin 2 180 here n there
i wouldnt be saying things like above in a public forum. As im sure you people are aware that police browse through these kinds of forums now and then...and it doesnt take much for them to obtain your ip address and get your info from your isp and be on your back for doing 170+k's
so be careful :cheers:
so be careful :rofl:
cheers dude,im back 2 dayshift now so 2much traffic 2 speed,was fun while it lasted:P
subaru rs 2.5L have nothing on the motorway
skylines r made 4 highways!
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
