Dont know if this really counts as performance or maintenance but i will put it in here anyway.
I had a compression test run on the R33 RB26DETT thats in my ceffy. Now most readings from a brand spankin new RB26 are about high 160+ or Low 170s or something.
Now i know when u do cam work and pistons and stuff that it will change the reading u get... BUT... will it change it so drastically that it would read 125psi across all 6 sylinders????
Can u guesstimate from that reading whats been done or not?
https://www.sau.com.au/forums/topic/54124-compression-test-readings/
The main thing I'd be looking at is the variation between cylinders. If you've changed cams and cam timing then the reading are going to change, and sometimes drastically. The variation will tell you if one cylinder has done a ring land or has a bad bore etc. The only time this doesn't apply is when you've blown all the ring lands or fried all the rings, but this will be evident in other ways!
Yep as the others said, variance is definitely more important because the absolute readings of every gauge are different. I would try disabling the injectors as I found they deflated the readings by upto 10psi. So pull the fuse to the ECU or disconnect each injector if its accessible! Oh and, dont forget to have all 6 sparkies out when you do it, and also have the throttle wide open!
As long as its fairly even across all the cylinders they should be right. Should vairy about 1 - 3 psi max each cylinder.
:wave:
Jun
1-3psi max?
have you tested 8 year old motors which put out readings that close to each other?
i was thinking more along the lines of 1-13 :wave:
what guage do u use? guages i have used u cant even see 1psi difference lol.
1-3psi max?
i was thinking more along the lines of 1-13 :D
If your getting 13 psi difference usally indicates you are losing a bit of compression with worn out ring lands and it will only get worse....
eg: testing RB25
Piston 1 - 160psi
Piston 2 - 163psi
Piston 3 - 162psi
Piston 4 - 161psi
Piston 5 - 162psi
Piston 6 - 150psi - Doesn't look to good!
Maby you can get away with a little more slack but on an old engine you carn't have 1 cylinder down a fair bit eg 13psi down and the rest fairly even :D It can result in time for a rebuild.
Not sure on what guage it was but just compression test.
Had one RB25 with cylinder number 6 on 0psi compression !!! :headbang: - I dont know how the thing started, it ran like a hairy goat :uh-huh:
:D
Jun
cameron, most readings i have seen are more random than that! ie there not one cyl that is way out compared to the rest, they are all a few psi diferent from each other....and yeah cyl 6 usually lower (first to get damaged)
could be the head though (burnt valves etc) which means a lot less to fix than bottom end and i would even bother because it probably wouldnt be noticeable if there was a diff of say 8-10 psi in one cyl..
in relation to the ceffy, like cam said, if they are even readings and it makes good power dont worry about it at all... if anything do a leakdown test to double check.
guages/cranking speed/battery/auxilaries etc all make sure you will never get a reading like new unless you are just lucky and the guage reads high..
eg: testing RB25
Piston 1 - 160psi
Piston 2 - 163psi
Piston 3 - 162psi
Piston 4 - 161psi
Piston 5 - 162psi
:D
Jun
your kidding right?It did have 5 other cylinders to push it along you know....
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
