I have just had a set of HKS Step 1 Cams installed in my 94 Series 1 GTS-t. The exhaust cam is 264* P/N 2202-RN175. The problem is the CAS will not mate up to the HKS camshaft, with has a totally different arrangement to the stock camshaft. Has anyone experiecnced this problem and is there a HKS part that can replace the part that is riveted onto the CAS that engages in the camshaft?
Thanks in advance
Ian
https://www.sau.com.au/forums/topic/54375-hks-camshaft-problem/
so you have it sorted now?
Nooo...not yet dnb...far from it....I am going to try and locate a R34 CAS and that should solve the problem, but apparantly R34 CAS's are hard to locate. Didnt really need all this drama..If the right cams had have been sent to me from Japan, this should never have happened.
Thanks dnb
Ian
yeah thats crap. have you installed them yet? maybe you can get them to send the proper ones? or a cas if youve installed them
Yes the cams are installed along with new timing belt and tensioners, water pump, seals. Dont want to take them out and send them back to Japan..I'll have to find a way of getting the CAS to work.
Thats kinna odd isnt it? why would you have a star drive CAS? I thought all the non-neo RB25 had half circle drive?
I have a HKS 256 exhaust cam P/N 2202-RN171 and it has a half circle drive and my CAS is also half circle drive. So doesnt this mean you need to look for R33 CAS?
btw, Im also looking for a CAS as mine is stuffed :(
I think its the opposite to what your saying lukits, the Series 1 and Early Series 2 have the star drive and the Late Series 2 and Neo R34 have the half circle drive in the CAS connection.
I have a Star Drive CAS working perfect for sale now. You can have it for $200 + postage.
Thanks lukits
Ian
ph.0414780869
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
