  • Replies 154
skyline geoff just left my place, he was tryin to convince me to mount TWO 4AGE's in a side by side V shape with a sandwich gear which would send power to the gearbox. When I said no that would f**k up weight distribution he then suggested running 2 CA18DET's east west in a configuration similar to an Audi TT twin engine car, one at the front and one at the back, each driving an axle and using sensors to detect wheel rotation and delivering power accordingly.
In the end we just decided to stick to a plain old simple CA18DET mounted north-south.
Ive been trying to convince my mate to remove the black stripe from the side of that car for ages..... this might just convince him for me :)
those black rims set that colour off really well, and the lower lip.... any chance i can find out where you got it????
4age costs about $1000 with loom and ecu
4agze about $1600
4afe bottom for a 1.8L conversion $500
realising that you can just put a CA18DET and get a lot more power... priceless.
Losing the sound of a 4AG(Z)E revving its tits off? A damn shame :P
Lucien.
ae86 in a factory turbo... nah, not according to all the sales catalogues i've got.
In the US the Corolla GT-S, and in europe the Corolla Coupe and in Japan the Levin and Trueno Sprinters, all had non turbo 4AGE's and other n/a variants.
  • 3 weeks later...
nie... locally delivered like ours. I got the trueno headlights in the mail, altho I'll need the fibreglass bonnet and guards to put em on, along with a body kit.
But first I'll concentrate on getting the CA18DET into the car, get my wideband O2 sensor happening and tune the ECU along with the Bee-R rev limiter (so I dun end up blowin the engine at high rev's like chris :)). Just finished gutting the car, next step is to fill the subframe with foaming eurathane to stiffen up the body and then rivet the skin to increase rigidity. For now I'll just run with a bootlid with reduced reinforcement (ie circular drill taking out chunks of the support bars on the boot n bonnet) until I get the fibreglass bonnet n boot. I picked up a 6 point roll cage for $200 (includes bar that goes behind the dash) but I've still gotta get it from japan.
Dunno if I'll run rear strut bar as I don't want the rear to be so still that I lose traction, but I'll probably use a really heavy front strut bar.
As an added bonus I found that my car actually had disc brakes all around and a mild suspension setup (unusual for a locally delivered model that's supposed to come with drum brakes on the rears owned by an old couple.)
Found some orignal tanabe rims on a DR30 in japan, that's the exact same offset, width and nut spacing... 14" diameter by 8" wide, which should be more than sufficient.
Project's comin along nicely... nice pics too upgarage.
Craved: thanks dude! Umm the lip i got off a dude on the Toymods.org forum the email is [email protected] and they do a pretty good kit and other fibreglass goodies for the ae86.
Duncan: I sold mine for 12k but really depends as always what work was done and condition, some are priced crazily some less..
And yeah, never any turbo ones released
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
