theres the kit for the GTS 4door, always wanted one of those if i was keeping the r31. try powerplay (i dont know any contact details) as they can get kits from japan for the r31..
saw a drift style bonnett from japan that was $1000 that i would have killed for...by the way do you have a 2 or 4door r31?
HOW & WHERE do you get these bits.
The links often don't work and I have been trying to get a Passage GT rear wing for my R30 for months.
I get told all these stories about everyone takes them off, but I can't find one for sale.
An R31 GTS-X rear spoiler would be cool as well or in lieu.
The side skirts would also fit the R30's.
I've been chasing a Passage rear spoiler for almost 2 years now.
I even drove all the way to Bendigo because i was assured that the seller had the one i was after, and when i got there it turned out to be a gts-x wing.
Talk about pissed off.
I got on to one in Melbourne about 12 months ago, as per attachment. It turned out the person selling was a kid of 16 and we agreed on a deal of $220.00 delivered to me in Sydney, but he procrastinated for about 8 weeks and eventually said he had someone in Melbourne to buy it for the full amount $220.00 and he didn't have to wear the postage.
And then I was pissed off, and have been looking ever since again.
I know how you feel.
if you want something like that then i have one in the boot of the r30 i'll post up a pic on mon as its still in the boot and the cars at the shop... its black, a hardish rubber and has some writing on the side, forgot what it says...
hey sorry net has been down for a while this thread got pretty messed up since i left :band: hey i mainly after realy nice bumper and sideskirts something to make the car look realy MEAN :) im not sure but i found this kit for a maxima how hard would it be to fit that to a R31? or is it just out of shape or simply to small/big ?
http://www.customautotrim.com/bodykits/kam...nari/maxima.htm
That place is in USA, the freight would be a killer. Probably better trying to get from R31 House in Japan.
Go have a look at Fibremaster at Arndell Park, they have all the old GS Motorbodies moulds. www.fibremaster.com.au
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
