I want to swap my front brakes for R33 brakes, I have a few questiosn that hopefully I can get a few answers on -
1) Is it just a case of swapping the calipers and rotors for the R33 ones?
2) Will the stock R32 master cylinder be ok
3) What rotors should I run - new stock or something a little better - will be using Racebrakes RB74 pads
4) Will they fit behind the standard rims?
5) Is there any other things I haven't thought of?
:D Chris
https://www.sau.com.au/forums/topic/54646-33-gts25t-brakes-on-32-gtst/
Some info on brakes, master cyliners and rotors
R32 GTST
Master Cylinder diam (mm) - 25.4
Front Caliper Piston(diam x qty) - 40.4 ×4
Front rotors (diam x thk) - 280×30
Rear Caliper Piston(diam x qty) - 38.18×2
Rear Rotors (diam x thk) - 297×18
R33 GTST
Master Cylinder diam (mm) - 23.8
Front rotors (diam x thk) - 296×30
Now the interesting bit...:P
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9
Front Caliper Piston(diam x qty) - (44+38)×2 ... leading pistons larger then trailing
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2
Rear Rotors (diam x thk) - 300×22
So there isnt much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR calipers.
If you want a brake upgrade id say go grab some DBA4000 meant for ther GTR , which are 324 x 30mm ...(DBA5000 if you can afford them) All you will need is a bracket to offset the caliper to suit the larger rotor.
Id stick with the std R32 GTST calipers. R33 calipers look better but hardware wise i think you will find they do the exact same job:)
Cheers for the info mate, the big thing for me is that they HAVE to fit under my 16" P1's, other wise there is no point me upgrading.
The main reason I want to go for the 33GTS calipers is so I run the bigger disk without fouling the rim, and being that bit bigger, hopefully they will do a decent enough job
Currently I am running some type of slotted rotor and racebrake RB74 pads, they work well, but I think with a bit more grunt and a upcoming driver training/track day early december, something a bit more substantial is required
What do you reckon?
O would not see any issues fitting the R33 brakes behind your 16" rims........R33's came stock with 16's, depending on the offset of your P1's you may require small spacers, simple fix.
If you do go ahead with this i would be interested in purchasing your R32 discs and calipers.
Cheers
Cheers
I will be going ahead with this, as I have already found some calipers and paid a deposit, just need to know if its going to be a simple task :D
PM me if you want mine and we can sort something out,
regards, Chris
Id use DBA 296mm rotors. The R32 GTST caliper is the same as the R33 GTST caliper isnt it. If it bolts to the hub and automatcally clears the larger rotot then fair enough, but im not sure if that will be the case. Intersting to see if the hub is different or the wings of the caliper are different
Larger master cylinder means the piston is bigger, sdo for say 10mm movement pisplaces more brake fluid so in theory should equate to a little more pressue in the lines?!?! I think, not 1000% sure
I know that the R32 caliper will not accept a 296mm rotor, tried that already :) from what I can see, the R33 caliper is mounted up a little more to make room for a bigger rotor
From what I can gather of the wrecker I am getting them of, its a simple case of unbolting the 32 calipers, put the 33 disc on and caliper and that should be it
I reckon you are pretty spot in re master cylinder stuff
Chris
They are bolting everything back on now, pipes and other shit, and tune is happening now I spose. I am leaving here in about 40 mins to go and hopefully see the final tuning etc and drive it home, Shaun reckons it should be all done by about 7ish, as they have to get the car out to make way for a few more booked in for tomorrow
Bummer about your car, at least they are not giving it to you until they are happy with it, should be great mate! :D
the rear disc size is 297mm as Roy says hehe
btw, R32 GT-R discs have angled cooling vanes in the middle, compared to the straight vanes of R32/R33 GTS-T discs. That, combined with its extra thickness and 296mm size, gives it better performance over extended track sessions (>10 laps). The R32 GT-R caliper is physically bigger than the R32 GTS-T's caliper, similar size to R33 GTS-T but slightly different design.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
