Anyone welcome to a fun day test and tune at benaraby off gladstone on 23rd november.So far:
*My 4 door--hoping for a really low 13 or even a 12
*3040 turboed series 2 gtst --hoping 11's
*T51 180sx ---hoping 12's
*Previously n/a silvia and 32 gts
*32 gtr
*32 gts-squizz's old beast--now doing 14.1's with an open diff
*180sx drift weapon
*bluebird sr20--doing 13's
*black huge turboed 33gtst
*silver series 2 gtst 33--13.6
*black series 1 33 gtst
*hopefully Ben and maybe a few more from streetmachines with their 11 second GTR's
and probably more and thats just from Rockhampton/Yeppoon, the local Gladstone boys will come too.Whack your car on the list if your coming.
I think it costs about $40 and scrutineering happens til about 1 and drags til 5ish.
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/
  • Replies 53
RESULTS:
*My 4 door--13.39
*3040 turboed series 2 gtst--didnt come
*T518Z 180sx ---squizz 13.45
*Previously n/a silvia and 32 gts --not ready in time
*180sx drift weapon--13.7
*black huge turboed 33gtst--kabooom bye bye pistons
*maroon gtst with t3/t4 hybrid--13.36
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-96711
SR20 with HKS T51 KAI will probably spool up at about 5000rpm, and should run 10s
CA18 with HKS T51 KAI will probably spool up at about 5500rpm, and should run 10s
Perhaps you mean TRUST T517z or TRUST T518z?
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-97143
yay for the skylines.....except mine:(
once again keeping those ankle biting little 4's at bay.
The fact that the skylines cost twice as much and were faster by .1 of a second means nothing.....heh heh.
That mph is awesome squizz, can't wait for next time, maybe some decent rubber would go down well.
As for me 300hp at the wheels and a stock computer just didn't go together ....too lean. Time to fit the t78 but not before the microtech and maybe a 3L bottom end.
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-97604
i think ill have to run hondy next time and show you all how to run 20's!!! go the N/A fwd dorift slug
Bad luck with the skyline garthos but i guess it was never gonna last like that.....:uh-huh:
And to Gti-r boy bagging squizz about 13.4's if ur car really has 164kws at all four why can't you crack a 12 when even a standard Gti-R can huh? You never had your Car and u never had Squizz. Rematch time this thursday..........:shake:
https://www.sau.com.au/forums/topic/5467-drags-at-benaraby/#findComment-97723
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
