I have done mine a couple of times,
my best time was 4.9 That was on a really good road with Advan tyres.
since then i have shitty falkens and my time has gone back to 5.5 - 5.9 depending on tyre pressure. my crazy japanese freind thinks i am getting good times due to the suspension setup?
I always thought my car was slow because i find it hard to break traction in a straight line.
is 4.9 THAT good?
is 4.9 THAT good?
How did you measure yours?
If its a genuine 4.9, then it is very quick
I didn't break it.
Driverside hub was done up too tight which killed the driver side bearing so it's un-drivable :(
I'm also having new brake fluid, pads, that sump put in and had the brake rotors machined (i liked the rear rotors having the burnt out chunks of rotor in there too cos of the straight steel pads in use on the back). Also putting in new boots onto the rack and changing some bushes on there.
Car should be good for a while after that *fingers crossed*
Shit I like your car too_much.. looks tough like rottawila :Pimp:
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
