Going back on the dyno after my 210rwkw read out on 8psi 2 weeks ago...
Could only run 8psi because the wastegate actuator was only holding 8psi.. now i fitted a aftermarket 14psi one and raised the fuel pressure up a bit...
Specs
RB30DET 25/30 Hybrid with all Stock 25det injectors / setup
Stock Internals
AVO Stage 2 cooler
3"
PFC
Malpassi
rx7 / t4 hybrid turbo
Im thinking the turbo has lots of room for more power if it made that reading at only 8psi ???
If it ran 210rwkw before on 8psi wonder what it could make now :mad:
Anyone have a similar setup with power figures?? will post a before and after dyno read outs
https://www.sau.com.au/forums/topic/54802-rb30det-going-back-on-the-dyno/
yeah u should be able to get that
stock inj have been used up towards 300rwkw reliably
you cant be serious about this ?
Stock 370cc injectors to make 300rwkw ??? how is that possible???
Sure 300rwkw could be done but the injectors will fail at some time breaking your motor.
Why do you think there are so many rb25's that run stock injectors and break once over the 240-250rwkw mark.
Look at the reliable RB25's that have held together.
Freebaggins 280rwkw is an excellent example running bigger injectors.
Guilt-Toy,
Do you have a boost leak? or is your Bov Venting?
Have a listen and watch the boost graph while on the dyno.
No boost leak or anything... it must be a waste gate controll issue... running a bleed valve.
You are right. In the morning i am going to put the boost down to 8psi and save up some more pennies for injectors...
Would GTR injectors be good enuf ?
Bleed valves are known to bleed down at high rpm.
Generally they will only hold ~2-3psi more than the wastegate can handle.
Either redrill the holes in your actuator bracket and make it an adjustable actuator :D or get your self an EBC.
I went with the redrilling of the actuator bracket.. Works well, takes a little fiddling though.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
