hey guys, i was looking at getting a GT3071R with a 0.64 rear housing on a T25/T28 flange. was wondering if this would push to much boost for my stock internals. i currently only have 044 fuel pump , 3" turbo back exhaust, FMIC. i would obviously be getting a ECU remap straight after and have already got a boost controller. ANY HELP PLEASE ? my goal at the moment is 200rwkw+ but am looking to go further in the future!
  • Replies 70
As many others would say...Do a search!!
But i can tell you that a 3071 is overkill for 200rwkw...plus the flange is wrong...how much more than 200 do you want? 250? 300? 500? decide on what you want and then research from there...for lowish 200s you have several options...
  • 1 year later...
what sort of power should i get with the following mods,
i just copied and pasted im aware the a few things wont increase how many kw i have ;) lol
Nismo GT-R Bodykit
East-Bear Bonnet
Koyo Radiator
GReddy Spec LS Front Mount Intercooler
Trust Airinx Pod Filter
GReddy Oil Catch Can
Apexi "Pencil Type" Turbo Timer
Swoosh Boost & Oil Temp Gauges - Dual Gauge Holder
RS-R* Piping from Dump to Cat
Trust MX Exhaust Cat Back
KYB Short Stroke Struts - King Springs
Endless Carbon Brake Pads
what are the next few mods that should be on my list to boost a power but keep it fairly comfy as a daily driver
cheers
thanks mate,
any hot tips as to the next mods?
want to be hitting around 180 - 200kw at the treads
Read all the replies in this thread? If you want a budget 200rwkw get a r34 rb25 turbo, nistune, a r34 sidemount intercooler and full 3" exhaust. That will see you 180-200kw depending on the dyno and tune.
All the other stuff you listed is just ricey mods you don't need. Also if you are going to do the suspension do it properly and get some decent gear in there.
Edited by Rolls
sorry i was a bit lazy lol.
are the springs in it at the moment not that good?
i dont want to change the intercooler i have on it already
sounds like a new turbo and a tune is the way to go.
Oh if you already have the intercooler then def stick with it, king springs are pretty awful, if you are going to go to the effort of changing them put something decent in. I assume you will be paying someone to do it and labour will be the bulk of the cost. As for shocks KYB aren't bad but you could get something better like koni or one of sydney kids bilstein packages for not much more. The ride quality and handling will be so much better.
edit: Are those mods what you already have done? or you are looking at doing?
edit2: I assume they are ones you already have. In that case yeah just look at a retune and an r34 rb25 turbo. If you do every plan on upgrading the susp then I'd look into the bilstein kits but as you already have them no biggie.
Edited by Rolls
sorry i wasnt very specific, im buying the car on thursday if the mechanical says its all good.
these mods are already done.
the ones i want to do will be out of turbo, fuel pump, ecu and injectors.
depending on how much money i want to throw at the car
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
