Ok geeks, help me build a 3D monster PC :D
SCSI drives are worthwhile if you can afford them. The throughput is much greater than IDE and you will notice the difference with applications that need fast drive access. 3D Rendering uses alot of system resources and alot of the response time will depend on the slowest part of the IO system, which is your hard drive. The faster the drive, the better your system response time. Some people may disagree but SCSI has a definite advantage for this type of system.
You could get away with using cheaper SATA drives for a RAID setup, probably RAID 10 would be best (speed benefits of RAID 0 with the redundancy of RAID 1). The downside is you will need more drives and only use half the space on them if you want redundancy. I still say go for SCSI drives :P Either way this system is going to cost you more than $2k :D
righteo. Well what would you suggest then considering a budget of close to $2000 and 2 X 19" CRT's, good audio card (keep hearing about AISO drivers or something), 3D mainly, but also After Effects (so i guess it's gotta be a mid-way between HD and CPU priorities i guess)
As you can see, i've got a sem-complete list already, but interested to see what you think.
cheers.
Yeah 2k retail :D
Let me put it this way for you
Seagate 73gb SCSI hard disk  - $770.00ex cost price
Seagate 80gb SATA hard disk - $83.75ex cost price
the choice is simple :P
Just slightly inflated prices there? :D Depends what RPM drive you're quoting.. You can buy a 73Gb Cheetah Ultra320 10,000rpm... for $455
http://www.auspcmarket.com.au/show_product...HD-SEST373307LW
It's true, a SCSI system will cost alot more than Serial ATA drives.. plus you would need a SCSI controller card too (another $300). but hey, you get what you pay for :D
BTW nice pic there Matt, looks mean!
Thanks, the big version looks awesome! Photo courtesy of Nick's Canon EOS 300D.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
