hey,
Today my car started making a ticking sound (loud, very audioable when driving) from the turbo side of the engine. It happen when on gas, fast, slow whenever i am on the gas i hear the sound, also if i put the foot down and go up into the rev range it sounds like its getting faster. It doesnt do it on idle, thou if i rev it it sounds to only make it around the 3/4000 rpm mark (the same spot my bov starts going off)
Now with all this in mind, on monday, my Oil line from my turbo to engine blow (was rubber not metal -- dont ask me) now i lost 4L of oil, my mech replace the line with a stock metal rb line, refill with oil and the car was given the OK that everything was working
Now from my limited knownage, i think it might be the turbo, its boosting fine and making power but it sounds like the ticking is related to the spinning of the turbo wheel (guess?)
I will have the car check out on monday (or maybe 2morrow), But if i cant get it in 2morrow it will wreak my head in untill monday can anyone help
thanks mike :D
Hey
I've had the same problem with my car. Does you car have a full exhaust system? This normally happens when you have a cat-back exhaust. You build too much pressure and you blow out one of the gaskets. So as you rev higher you can hear it louder as it is leaking more air. Try getting an exhaust specialist out. Are you in sydney? Give me a yell if you are! Got someone that can help!
Phil
Yeah most likely its gonna be the one of the gaskets. I've blown one before and in the verge of blowing another one. Just get your car checked out by an exhaust specialist. It should cost around $300 mark. If you know the guy you might get it cheaper!
If it was the turbo it would be a very fast noise, almost a buzzing but if it is a ticking and you lost that much oil I'm considering a big end bearing. Get it checked fast and don't drive it unless you have to. The bearing and journal can sieze causing a conrod to snap which will destroy your engine.
Sorry if it sounds over the top but it isn't worth destroying an engine. I had one in mine and the ticking/tapping noise was quite loud in the garage and seemed louder on the left side.
Drop the oil and look for golden coloured metal specs and flakes. If they are there a bearing is going. In that case a rebuild is needed, probably with a crank and conrod big end grind. Sorry to say will be expensive if it is but you get to rebuild a decent engine that will last ages.
I hope it is not that bad but from what you say, it seems pretty clear.
michael ,
it sounds like a big end sorry to say mate .
do this little test . when the engine is cold ( stone cold ) start it up and listen for the noise, it should be very mild while the engine is cold ( thick oil takes up the slac on the bearing ) .
when the engine and oil gets to normal operating temp the noise will get louder , if thats the case then its a big end .
michael ,
ok i just did that test, the sound is louder when the car is cold, when the car comes to normal oil/rpm/temp it becomes very quite and u can bearly hear it. give the car a few revs and it comes back for a few seconds :s
i am very confused
exhaust leak, most probably the manifold bolts/studs loose or broken or about to break.
tighten the bolts up, but there is a fair chance that some might break so take care.
Apparently this is a common flaw with the rb engines - dodgy exhaust manifold bolts!
The botls snap.. I had EXACTLY the same thing happen to me at wakefield park. Turns out my exhaust manifold had a slight warp in it and had snapped 6 of the bolts. Its very common on skylines
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
