Guys the 2530 is a tarted up Garrett GT28RS and the GTRS is a tarted up Garrett GT2871R . Search ATP Turbo.com for details , Brett at GCG should be able to import and emulate the things for nothing like $4000 . ATP will also sell either cartrige seperatly for under $1000 US . For the record the GT28RS comes with a .86 AR turbine housing which is essential for 2 liters and up . The only problem is I'm not sure if Garrett or HKS make a T3 flanged .86 housing . Brett is having adapters made up and the combination will work heaps better than the .64AR . Std dump wont fit though SR20DET ones will . Cheers A .
  • Replies 57
After reading lots and speaking with people, I decided on one step up from the 2530 being the 2535 on my RB25. It certainly doesn't make 511rwps or even 438rwhp for that matter but the best i've seen out of it is 339rwhp @ 16psi and more recently, i've had it "street" tuned at only 12psi for 300 rwhp. Now I can tell you 220rwkw in any gear is a lot of fun. I've not run the track yet but I'd hope for low 13/high 12 and if Sly33's results are anything to go by, it should do it. Given that 12psi is hardly in the HKS 2535's efficiency range, it's safe to say that if I were to wind the boost up and get it retuned, everyday 250rwkw would be easy. Unfortunately for me, the fuel pump and my injectors don't keep up with that power for the moment so I've left it at 12psi.
The 2530, 2535 and even the 2540 are not big turbos. If you're chasing the big numbers, don't get one. If you're after quick response, good street power and about 250rwkw, buy one and be happy ;)
339rwhp@16psi
Would it be necessary to lower compression at that ammount of boost? or can the RB25 handle a bit more?
I know it depends on the tuning, but just wondering what kind of boost people with GT2530/35/40 are running to make max power with standard compression
If anyone is after a HKS turbo upgrade get the GT-RS! my mate has this installed (at BD4's) and its nuts! I will have mine on in a weeks time just labour at the moment. The gt-rs is honestly nothing short of nutz! 1st to 4th gear is just wheelspin without dumping clutch, no lag, consistent power curve. The car really get's up and goes. I will make a thread on this in the coming week and show all the results. So far i highly reccomend it!
339rwhp@16psi
To be quite honest, I wouldn't know. I've got a fully rebuilt RB25 with forged pistons so I don't have to worry quite as much. Mine happily boosted away on 16psi but my PFC flashes up 100% duty cycle on my injectors which is why my street tune is back to 12psi. Once the injectors get upgraded and the fuel pump upgraded, i'll probably screw 18psi into it as that's where these turbo's like to operate :) (approx 1.2bar)
Do these come in T3 flange? I thought they were only GT25?
GT-RS has same compressor housing and turbine wheel as GT2535 and GT2540 but a bit larger trim if i'm not mistaken. Although output on GTRS is 400 vs 340 and 350 on the 2535 and 2540 respectively. All are slightly larger than 2530 which is what this thread was about in the first place.
I am pretty much in the same boat at the moment, and am not too sure that I can afford a reasonably larger than stock turbo - let alone the supporting mods right now.
I have been doing some research, and it LOOKS to me based on the comments throughout here on GT2530s etc that a TD05-big 16G from a Mitsubishi EVO3 (and some others) would do a similar job. They seem to be good for the 340-380hp range, depending on where you look and how you set it up. I've actually not found any solid evidence of anyone running one on an RB motor, especially RB25DET. Does anyone have any thoughts on this?
I realise I'd need to do some mods to use it - but considering I can get one for $500-600 its not too bad :)
Mitsi turbos
339rwhp@16psi
Well when i first got my car back, it had been tuned to be safe at 1.39bar! Straight away i voiced my concern to my tuner but he assured me its safe. On cold nights i regularly see 1.39bar. I have a completely unopened motor with the stock 9:1 compression. I do get the occasional knock if the fuel is bad. Many would say thats excessive, and id even agree with them! But so far its been fine, and as i plan to rebuild the motor soon anyway it doesnt bother me. So going on how my motor handles it, id be saying 1.2bar with good tuning should be fine on a "healthy" motor, although for peace of mind go the head gasket and 8.5:1 comp.
as for the GT-RS, its a newer turbo rated higher than the 2530/35/40 and designed to fill the power/response gap in the old GT series, so i dont doubt it'd be the pick of the bunch, but as with every other mod, it depends on how much you want to pay, as the old GT25 series can be had fairly cheap even brand new.
What are they croat.The 400ps rated gtrs with t3 flange and all acessories For the gts-t $2564.55 from nengun.
If i were to run a gtrs turbo and wanted 230 rwkw,for now untill i had enuff money for a rebuild on the engine,what psi would it be running at.Knowing that i have all the supporting hardware bar turbo and forged bottom end.
I think these turbos run up to 300rwkw.If i am correct about what a ps rating is.
Can someone explain to me what a ps rating is.
Trust33 ps means "power stroke" its approximately 400hp rated (thats what i have been told). The turbo come with all accessories you need to fit it to your gtst, gaskets, lines, elbow etc... I have the turbo and have standard bottom end, and so does my mate. He runs 1.3 bar all day every day, i will run around 1 bar (just to keep things safe). At 1 bar i am expecing around 240 rwkw. I think this turbo can run up to 300rwkw but u will need forged internals and a lot of boost, cams etc... Trust33 why rebuild the engine if you dont need to, just wait till it dies.
Bolts up easy to stock manifold and dump (i will find out for myself next few days). I think the gt-rs will be too small a turbo for an rb30, better off going a 2835. My oppinion...
Thought the gtrs was a bigger turbo - people seem to be getting more power from these than 2835??!!
    • Engine turning over but not starting.
    • Just checking, does the engine turn over and not start? or is it just a single click and doesn't turn over at all?
    • Hi SAU family, having issues with my R34GTT which is slightly modified and tuned to e85. so scenario is, I’m driving the car to work (30km oneway) and then coming back in the arvo. Car starts and runs fine in the morning and on the way back home (in the arvo). I stop the car when i gets home and after 10-15 mins, it wont start. Battery is fine, fuel pump seems to be working. All i hear is engine clicks but wont start.  Last time, i disconnected the battery terminals and re connected them. Check fuses. Didnt start at that time but started after an hour (so I say when its cool down). Mechanic cant find the issue as its running now and nothing coming up in the diagnose. any advice,opinion or anyone gone through similar issue.   thanks 🙏🏻
    • 9" +35 will rub on the suspension. R33 GTR wheels are +30.
    • I know a guy with 18x9 +22 on the front of a 32 gtst, needed quite a lot of guard work, tyre stretch (215) and camber. Not sure what your current set up is, +35 won't be as much, but still a fair bit of guard work and camber.
