OK After slowly collecting parts for the past couple of years i am now about to start the buildup of my 33 gtst. The way it is at the moment is pretty much completely stock except for a carbon bonnet and 3" Dump and exhaust with apexi n1 muffler.
I plan to do this in 2 steps, first get all the bolt-on items done and tuned for low boost then second step simply internals ( forgies, rods, balance ) and add more boost.
I have so far colleced the following for my stage 1.
Greddy Plenum
Q45 throttle body
Q45 AFM
HKS 3037s
Manifold
HKS wastegate
(steve's old 320kw setup)
Hybrid 600*300*76 intercooler
Apexi PowerFC
Apexi AVCR
HKS adjustable cam gears
bosch 040 + 044 fuel pumps
SX adjustable fuel reg
Fuel surge tank
Tomei timing belt
Nissan Inlet and Exhaust gaskets.
tomei 256 poncams
nismo 740cc injectors
What else am i missing, or what suggestions have any of you guys got before i start this.
***now also have Argo rods, Tomei 256 poncams and springs, ARP head stud kit. Just Jap Oil cooler Kit.***
Edited by B33st
https://www.sau.com.au/forums/topic/55170-the-b33st-buildup-hks-3037s/
  • Replies 91
dude thats like exactly the same set up goin in my 33, good to see the results, mine wont be ready till probably april/may next year, just finishin some things on the car now (looks and interior) then i can save for fitting and tuning since i have alot of the egine parts already...
she's gonna run sweet mate, have fun when its done...
btw, u gettin the .63 a/r or .87, im goin with the .87
sourced a few parts from nengun which made the whole process a fair bit cheaper...
good to see ppls comments so it helps me as well...
cheers...ben.
i would do internals 1st :) i think it would be cheaper tuning wise as u would only have to get the car tune once and there is no chance of u braking it before the internals r put in, if u get me :D
just something to think about dont wanna do all the bolt-on mods and damage the engine then have to wait for the cash to come in to get the internals done
mike
Ben, the 3037 has the .87 exaust housing. Its steve's old turbo setup, check out his thread.
Mike, steve was getting 321rwkw with stock internals, so i should be alright running low boost for a few months.
I personaly would do internals aswel. A set of forged pistons etc.
As you will save muking around later down the track when you will have to pull out the engine to get it bored & honed.
To make the most of your set up i'd do internals, As for steve's car their are other components that have made he's engine reliable - Lower compression = less detination. but too low compression also = slug coming onto boost, so you have to weigh it up. So an aftermarket head gasket is what i would reccommend.
If you do internals now you'll thank your self later. - Trust me ;) - depend on your $$$ aswel, so its up to you at the end of the day.
other than that its a very good package and show'd go very well.
:D
Jun
Greddy Plenum
Q45 throttle body
Q45 AFM
HKS 3037s
Manifold
HKS wastegate
Apexi PowerFC
Apexi AVCR
bosch 044 fuel pump
Fuel surge tank
Tomei timing belt
tomei 256 poncams and nismo 740cc injectors on there way. (cams will probably go in with internals and a slight port.)
Nice!
Got similiar parts installed on my car already except turbo is a Garrett GT35 and boost controller is HKS EVC 3.
Do the internals first before it blows and save youself alot of labour costs from getting everything installed and then removed to get the internals done later.
Yes.What a list of mods and no cooler.especially when the car will see the track and street.the oil will get a longer life helping the engine out also.
Go the oil cooler.Go to the group buy section and get one or go to the oil cooler advertisment by shift performance in the bussiness thread.They are different sizes though i think the shift set comes with sandwich adaptor,oil filter relocator braided lines and cooler(13 row i think) and can only be bought as a set.but the group buy one by meridan you can mix and match different combos but they only sell a 19 row oil cooler i think.
You certainly have a list on your hands i wish it were me....Aggggh! :drooling:
im in the same situation, so what combination of internal work would be best, ie, which pistons, rods, etc??
any help appreciated
ben...
Arias forged pistons seem to work 100% fine.
As for rods you can do a combination of
Arias pistons & Standard 25 rods and crank - Cheep option - but this limits you with reving your car past 7k - also your stock interal head limits that aswel (valve's & springs etc)
Better way to go would be: Arias Forged Pistons & RB26 rods with standard crank. - with balancing etc. - You can rev upto 8000 rpm easily. - need some head work though.
Or expensive option is: Arias Forged Pistons and Forged conrods. I've fround that Crower & eagle do good rods at reasonable prices.
Other brands of pistons.
Arias
Venoli - Not sure on spelling
Wiseco
HKS
JUN
Grex
Tomei - etc you get the drift.
hope that helps,
Jun
It definatly will see some track work but will probably be more 1/4 mile initially. Oil cooler is going to be added once i get the thing up and running.
On the subject of rods, anyone used the forged revs ones that hioctane are selling for around the $1500 mark.
