http://www.cartracingupdate.com/News04/310...generalcart.htm
Reading this above article it says that they can run boost levels from 41.5 - 44 inches of mercury...
Could someone please help me out to do the conversion in PSI or Bar please?
I mean if this is using the same measurement as whats on the standard guages in skylines then they would be running upward of 6 BAR or 84 PSI.....
Is this correct?
If so that awsome.......
https://www.sau.com.au/forums/topic/55461-what-boost-level-do-champ-cars-run/
inches of mercury and psi are almost the same.
if i remember correctly, champ cars run around 44psi.
cheers
Linton
Nah...they definately don't run that much boost. 44 inches mercury is just under 1.5 bar. But I think they are refeting to absolute not relative pressure, so it is about 0.5 bar or about 7 PSI, which is about what I always thought.
This is taken from one of the CHAMP car sites-
· Nominal power: 750 bhp at 1054mm Hg (Maximum intake pressure on road circuits. When on ovals maximum is 990mm Hg)
· Maximum power: 800 bhp at 1130mm Hg. This amount of power is only unleashed when push to pass is activated. This system was developed in 2004 at request of Champ Car aimed to increace overtaking. This is a procedure where each driver has the opportunity to increase engine power by 50bhp, for a maximum of 60 seconds per race. A steering wheel-mounted button activates the system and a combination of increased turbo boost and fuelling provides the extra power, to allow drivers to mount a passing move or fend off competitors.
1 mm Hg (or millimetre of Mercury) is equivalent to .001316 atmospheres.
This would then equate to a maximum boost of 1.487 bar or 21.57psi or 43.91 inches of mercury
Yes, but I am quite sure that that is absolute, not relative pressure. You need to subtract 1 bar from those figures.
Just came across this - different again
"Over the past few years, as speeds rose, CART reduced the amount of boost from a whopping 45 psi down to 34, using pop-off valves. The valves are electronically monitored by sensors. The only way for teams to get power up was by increasing rpms, which was costly. "Part of the cost savings this year was our ability to reduce the rpms back to 12,000. But to bring the power back up again, we increased the boost," says Bisco. Currently, 41.5 psi blasts through the turbocharger, making 750 hp at 12,000 rpm. "
i very much doubt that its not absolute. Pretty much all car related stuff is in relative. Even if you did subract 101.325 kPa from it (1 atmosphere not one bar even tho they are close) it would run under .5 bar!!! thats stock skyline territory.
Yep they will run 40+psi all day as they are specially designed turbos made with exotic materials like titanium shaft and wheels.
I seen a champ car engine up close which was on display at local autobarn a few months ago. The turbo looks the size of a garrett GT40 but would cost 10 x as much
If he said 40mmHg, then that means they are running 80psi.
Unless I am very much mistaken, the standard skyline boost guage is in mmHg, and 3.5mmHg=7psi...
So i'm not sure where you're figures are coming from saying that 40mmHg = 1.2 bar
40 "inches"
"INCHES of mercury"
not mm
INCH
LOL...dont know what turbos they run today, but it was only a few years ago that they ran plain bearing turbos from Allied Signal and Holset. Hell in '96 (or around then) Ilmor / Mercedes ran a pushrod engine as the rules allowed them to run more boost.
It would not surprise me if these turbos were still used as there arent many BB turbos the size that they run. If you want massive boost on race engines look at some of the Pikes Peak cars, and some of the older Le Mans cars...occasionally they got up around the 2.0bar
http://www.skylinesaustralia.com/forums/sh...&highlight=Indy
Can anyone explain how the "on-demand" turbo boost works then?
Coz on our cars boost is driven by RPM.
Like the 'scramble' button on some ECBs I would have thought.
And just pointing out if anyone doenst know, they are running a control cosworth engine these days which as far as I know have a larger capacity than the older pre control engines. Sooo at a guess as they are a control engine they would have to be more reliable, there for more capacity, a bit less boost... So once again at a guess I would say (for a race car) they are running a fairly conservative tune.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
