http://www.cartracingupdate.com/News04/310...generalcart.htm
Reading this above article it says that they can run boost levels from 41.5 - 44 inches of mercury...
Could someone please help me out to do the conversion in PSI or Bar please?
I mean if this is using the same measurement as whats on the standard guages in skylines then they would be running upward of 6 BAR or 84 PSI.....
Is this correct?
If so that awsome.......
https://www.sau.com.au/forums/topic/55461-what-boost-level-do-champ-cars-run/
inches of mercury and psi are almost the same.
if i remember correctly, champ cars run around 44psi.
cheers
Linton
Nah...they definately don't run that much boost. 44 inches mercury is just under 1.5 bar. But I think they are refeting to absolute not relative pressure, so it is about 0.5 bar or about 7 PSI, which is about what I always thought.
This is taken from one of the CHAMP car sites-
· Nominal power: 750 bhp at 1054mm Hg (Maximum intake pressure on road circuits. When on ovals maximum is 990mm Hg)
· Maximum power: 800 bhp at 1130mm Hg. This amount of power is only unleashed when push to pass is activated. This system was developed in 2004 at request of Champ Car aimed to increace overtaking. This is a procedure where each driver has the opportunity to increase engine power by 50bhp, for a maximum of 60 seconds per race. A steering wheel-mounted button activates the system and a combination of increased turbo boost and fuelling provides the extra power, to allow drivers to mount a passing move or fend off competitors.
1 mm Hg (or millimetre of Mercury) is equivalent to .001316 atmospheres.
This would then equate to a maximum boost of 1.487 bar or 21.57psi or 43.91 inches of mercury
Yes, but I am quite sure that that is absolute, not relative pressure. You need to subtract 1 bar from those figures.
Just came across this - different again
"Over the past few years, as speeds rose, CART reduced the amount of boost from a whopping 45 psi down to 34, using pop-off valves. The valves are electronically monitored by sensors. The only way for teams to get power up was by increasing rpms, which was costly. "Part of the cost savings this year was our ability to reduce the rpms back to 12,000. But to bring the power back up again, we increased the boost," says Bisco. Currently, 41.5 psi blasts through the turbocharger, making 750 hp at 12,000 rpm. "
i very much doubt that its not absolute. Pretty much all car related stuff is in relative. Even if you did subract 101.325 kPa from it (1 atmosphere not one bar even tho they are close) it would run under .5 bar!!! thats stock skyline territory.
Yep they will run 40+psi all day as they are specially designed turbos made with exotic materials like titanium shaft and wheels.
I seen a champ car engine up close which was on display at local autobarn a few months ago. The turbo looks the size of a garrett GT40 but would cost 10 x as much
If he said 40mmHg, then that means they are running 80psi.
Unless I am very much mistaken, the standard skyline boost guage is in mmHg, and 3.5mmHg=7psi...
So i'm not sure where you're figures are coming from saying that 40mmHg = 1.2 bar
40 "inches"
"INCHES of mercury"
not mm
INCH
LOL...dont know what turbos they run today, but it was only a few years ago that they ran plain bearing turbos from Allied Signal and Holset. Hell in '96 (or around then) Ilmor / Mercedes ran a pushrod engine as the rules allowed them to run more boost.
It would not surprise me if these turbos were still used as there arent many BB turbos the size that they run. If you want massive boost on race engines look at some of the Pikes Peak cars, and some of the older Le Mans cars...occasionally they got up around the 2.0bar
http://www.skylinesaustralia.com/forums/sh...&highlight=Indy
Can anyone explain how the "on-demand" turbo boost works then?
Coz on our cars boost is driven by RPM.
Like the 'scramble' button on some ECBs I would have thought.
And just pointing out if anyone doenst know, they are running a control cosworth engine these days which as far as I know have a larger capacity than the older pre control engines. Sooo at a guess as they are a control engine they would have to be more reliable, there for more capacity, a bit less boost... So once again at a guess I would say (for a race car) they are running a fairly conservative tune.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
