Do japanese car makers offer diesel engines in Japan,like in Europe were they have to offer diesel engines because of Bmw,Wolkswagen etc?
Do they even offer diesel besides petrol?
Diesels are available, but no one ever uses them. They're mainly used as company work hacks. The 4WD's are about the only passenger vehicle on the road here that run on diesel.
IG
https://www.sau.com.au/forums/topic/55469-tdi-cars/#findComment-1081543
Diesel is being phased out for passenger cars due to emission, so it is incorrect to say they are not readily used. Nearly every make and model there is a diesel version. Which is why my exporters like a mate is making a killing sending luxury diesel cars especially 270D back to UK and other european countries :D
Though it is largely used by commercial vehicles, which will still be available for a little longer before they all change to fuel cell.
Brian, correct so does the bluebird, sunny, crew...etc...
https://www.sau.com.au/forums/topic/55469-tdi-cars/#findComment-1081660
around 120-125 per liter for hai-oku hehehe i think. i stopped getting gas from the gas station since the place im living in contracted exxon, so now im paying 1.43 us dollar per GALLON. haha!
isnt the toyota hilux diesel too? saw one in ryugasaki 0-400 m finished in 14 secs. hehehe.
i heard that theyre gonna get rid of all diesel (or mostly) cars here in tokyo because of pollution. like my friends hilux shaken is due this month i think and they wont let them renew.
https://www.sau.com.au/forums/topic/55469-tdi-cars/#findComment-1083504
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
