Power vs torque
Guest mightymax
I cannot figure this out maybe some fellow forum members can help me out.... :)
What influences power and torque?
1.)For example running increases stamina/endurance while wieght lifting increases strength for human...
For cars what mods increase power or torque???
OR
2.)Is it dependent on the nature and characteristics of the ECU?e.g.power fc vs possumlink
OR
3.)Can the tuner trade off power and torque?
Foe example:car A: 100kw(power) and 50nm(torque)
car B: 50kw and 100nm(torque)
Which car would have a advantage on a flat surface and a steep slope?
https://www.sau.com.au/forums/topic/5553-power-vs-torque/
Torque is a twisting force, just the same as you would apply with a spanner to do up a nut.
Fifty foot pounds of torque is like a fifty pound weight on the end of a one foot spanner. Or five pounds of force on the end of a ten foot spanner.
This is simply a force pushing, pulling or twisting on something.
Power is the rate of work being done, or force times speed. If you do something twice as fast, it requires twice the power.
So, power equals torque times speed. expressed Ft-lb x RPM.
A long time ago a guy calld James Watt got himself a genuine hairy horse, and did some measurements to see how much weight his horse could lift or drag in a certain time.
He decided that his horse could lift a 550 pound weight one foot each second, and this has now become the standard unit of horsepower. True !
We now have the formula , Horsepower = Ft-lb x RPM / 5252
Getting back to internal combustion engines, torque is twisting force only. The main factor deciding torque for a non supercharged engine, is the size of the engine, that is the bore, stroke, and number of cylinders.
Power for a heat engine is the rate at which air and fuel can be burnt in a given time. So power has more to do with airflow through the engine than the size of the engine.
I small high reving motorcycle engine can make a lot of power because it can spin so fast, but will not have a lot of torque because it is small.
A huge truck engine will make a lot of torque because it is big. But because it cannot spin fast the power will be relatively low.
A gearbox can reduce the speed of a shaft and increase the torque at the same time, but the power remains almost exactly the same.
So a one hundred horsepower motorcycle engine fed through a reduction gearbox can produce the same torque and RPM as you would get straight from the one hundred horsepower truck engine.
Does that help ?
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-84273
Okay - easiest way to get more torque is to increase capacity. Now how do you do that on a motor? Increase the boost.
If you want more power, you play with your mixtures, let the motor breathe better, etc etc...
matt
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-84666
Power=Torque*RPM*a constant
If you make good torque at high RPM you make good power, and can take better advantage of gearing.
My last car was a Civic VTiR, which had bugger all torque, but peak torque was over 6000RPM, leading to peak power of 118kw at 7200rpm.
I am driving a 3L diesel lowlux hire car at the moment, which has heaps of low torque but this drops off well below the 4500 redline:uh-huh: . It can accel up a steep hill in fourth at 1700 rpm, but would do a 0-100 in 15 seconds.
Power is all about where your torque is in the RPM range.
As an aside dynos don't measure power they measure torque and calculate power from this and tyre rpm or tacho rpm.
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-84709
Exactly! I'm glad someone pointed this out.
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-85260
Originally posted by Warpspeed
Torque = acceleration, power = speed.
You got that around the wrong way. With a lot of power you can gear it down for very quick acceleration, but without the torque your top speed will suffer. So on a simplistic basis, you could say that power=acceleration and torque=top speed. Of course gearing affects this, but that's the basics.
A lot of people talk about fast drag cars which have a lot of torque, but these also have a shitload of power. Take a look at a Mack truck. It has mammoth amounts of torque but not too much power (on a relative scale). They accelerate like slugs but can still get up to well beyond highway speeds. You're not going to run a 9s quarter mile on a normal truck engine no matter what your gearing is.
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-86801
Well jim your half right.
I still say torque = acceleration. Which gear gives the greatest rate of acceleration, first gear or top gear ? Why ?
Tractive effort is what accelerates the vehicle.
Now if you want to talk about the fastest way to cover a certain distance, that is different thing altogether. What you need is the HIGHEST AVERAGE SPEED to cover a given distance in the shortest possible time.
For this you need high power, because time becomes an important part of the problem. So yes, high power is the most significant factor in getting a low ET, or high terminal speed.
So power = speed.
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-86848
Warpspeed,
Torque is the only thing acting on your wheels, so you're splitting hairs here. The simple reason why your car accelerates slower in a taller gear is because you are reducing the power to your wheels. Have you ever seen a dyno chart? The torque curve stays fairly flat all the way along, but the power goes up with the speed and eventually tapers off. If what you were saying was true it'd be the other way around.
What I'm saying is if you have a high powered engine with not a lot of torque, you can compensate for a lack of torque with gearing, which will improve your acceleration but won't improve your top speed unless you had a really short ratio, and you lengthen it to the point of finding the engine's torque limits.
Once you're past the threshold of your maximum torque, no amount of gearing will increase your top speed. Even if you're not redlining, eventually there will be a gear ratio that will limit the vehicle's top speed. It is a lack of torque here that's stopping you going any faster, not power. Therefore you could say that the amount of torque governs your top speed.
Your example actually illustrates this. You're talking about a high terminal speed. You're using power to accelerate to this speed, not maintain it. So yes, you need a high powered engine to get to that point as quickly as possible, but the actual speed you can reach is a reflection of your torque.
Even most normal cars have enough power and torque to keep accelerating way beyond the standing quarter mile so it's not a very good example. I have ridden 250cc motorcycles that can accelerate quite quickly to about 130kph, but the top speed is like 150 and the acceleration from 130-150 is much less than from 0-130. When at 150 in top gear, the engine is way below redline but it just won't go any faster even if you drop it back a gear. These bikes have high powered engines (40hp or so) but very little torque, which is why they can't go any faster.
I maintain that I am entirely correct, and even your example proves this. If I'm half correct then that means you're also half correct, which means we're both correct? That doesn't make any sense :D
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-86857
I have read through what you said a few times, and cannot disagree, I think we are looking at the same problem from a different angle.
For instance you say when you go up a gear the power to the wheels drops because engine RPM drop. Quite true, I had never really thought of it quite like that.
And as you say if the torque curve is (almost) flat, then the torque at the wheels will drop because the reduction ratio through the gearbox is less in the higher gear. It is really saying the same thing but looking at it from a different perspective.
When gearing a competition car for maximum performance it is the power curve that is most important. Gearchange points should be either side of the maximum peak power point so maximum area through the power curve can be used in each gear.
The torque multiplication through the gearbox will be maximum under these conditions in each gear, giving greatest acceleration.
If you only rev it to the engine torque peak at the same road speed, you will be in a much higher gear, and actual acceleration will be less.
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-86869
Warp u sumed it up with this statement, I was wondering who would get it right first 10 points.
"Gearchange points should be either side of the maximum peak power point so maximum area through the power curve can be used in each gear. "
totaly true. thats how i geared my car
my car only uses a 1500 rpm rev range
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-86944
Guest (_W.4.S.P._)
this is a great topic ,,
For cars what mods increase power or torque??? c'n'paste
so torque will get increased by a longer stroking engine or by a larger cubic capacity
and
power will increase by getting more revolutions per minute onto the rear wheels ?( motor, g box , diff ? )
umm ,, side Q? ... what stops a cummins turbo deisel from reving to 9000 per min? roller bearing the thing and put it in a gemini and bombs away ????
https://www.sau.com.au/forums/topic/5553-power-vs-torque/#findComment-86968
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
