That sounds very bad, cracked head could leak coolant into the cam cover, from there it could end up in the catch can.
Ther is another posibility, which may be a little less worrying. The reaction of petrol (mostly octane) produces carbon dioxide and water vapour. You could be getting blow by (CO2 and water vapour) and the water vapour could be consensing in the catch can. I would have thought that it would have boiled off again (and ended up being scavanged throught the intake if you have the scavanging system operating).
It is hard to tell which is more likely without seeing the car, I'd need to know:
1) did you find the water when the engine was cold or hot.
2) did you find it right after the engine was running or had tha car sat around for a while.
3) how much did you find
4) could you tell if it was coolant or plain water.
5) is there way the water could have leaked in (is it a atmo vented catch can)
It will probably become obvious if it is a cracked head before long so lets hope thats not it. Blow-by is no big deal, even new engines have it, just gets worse over the life of an engine from wear, eventually could require a rebuild.
I don't see how a blown head gasket could leak coolant into the cam cover.
SLY SKY: open up the cam cover (or even just the oil filler cap) and have a look around,
can you see water? (lets hope not),
can you smell water? (got a strange musty smell usually)
is the oil milky at all (maybe drain the oil and check).
Get back to us and tell us how it went.
It builds up say after 2>3 weeks, its clear not green. About a cup full.
My water level is always the same, at oil changes everything looks good if a blown head gasket the water in the radiator should drop. I thought it might be condensation. I don't know. :alcoholic
Clean as looks normal, oil fine. :burnout:
Its only condensation mate. Totally normal during the winter months. From the responses you've received thus far I'd take it the other guys aren't running a catch can.
Sleep well tonight.
Thanks dude, youre right it has only started doing it in the last few months. :thankyou:
hi mate, my 33gtr has a cusco tank on it and it fills twice a year about a pint. done this for the last few years. never loose,s water no oil contamination. if you do short bursts and it damp weather the engine will absorb moisture from the atmosphere as it cools. normalyy [without a catch tank] it is sucted into the turbo and burned, but this lowers the air density in the chamber hence less power, catch tank takes the moisture away from the turbo.just empty it and carry on as usual. hope this helps..............bernie/uk.
"EMPTY THE CATCH CAN"! I didn't know you had to empty it as i did an oil change the other week and i didn't even give it a thought. Mine is a GREDDY can, (side mounted) is it just a matter of disconnecting hoses and tipping upside down, or do you have to take it apart?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
