fair enough.
given the pics, it seems that it could be a HKS GT2540R as they were the only turbo in the HKS GT25xx series which cam with the A/R .50 compressor housing and the A/R .86 exhaust housing.
what flange does it have, GT25 or T3?
Unfortunatly the middle pic hides the core so cannot tell if its a ball bearing type . One easy way to tell is to count the bolts on the core side of the exhaust housing . Four bolts means bush bearing and six bolts means ball bearing . That turbos compressor cover is a TO4E .50AR . I forgot to see if there is a divider web between the turbine outlet and wastegate outlet . If it has this and the four bolt exhaust housing its a Garrett Hybrid . I have seen something similar to this but with a .60AR B cover from Garrett . For positive ID really need to remove the compressor cover and measure major and minor diameters . This will tell the whole story . I have not seen HKS use that .86AR exhaust housing and turbine combination on their 25 or 28 series BB turbos .
Chow DPO3 .
Fair enough so BB core with NS111 turbine . Still need to see comp wheel , unscrew the six bolts on the backplate adapter and carefully slide it off . If the major diameter is 76mm (3") its probably a 46 trim TO4E wheel making the turbo a HKS GT2540 . The only one of these I've seen was GTR specific and used a .64AR turbine housing and I think a T3 style compressor cover . It makes sense to use the larger housings for a single turbo application but most agree the 2540 is not a good pairing of compressor and turbine wheels . My own opinion is that turbine is best paired with the 60mm compressors ie GT2530 / GT28RS and whatever the GTR Skyline upgrade turbo is called .
Any how whip off the front cover and all will be revealed , Cheers A .
From HKS there are three versions of the 2540 all using the same core and wheels . The first has a T3 flanged .64AR exhaust housing probably aimed at RB20/25 for R32/33/34 . The other two have the 2540R designation and the difference is .64 or .86 AR T25/28 flanged exhaust housings . The two "R" versions are probably aimed at the Rb26 and SR20 engines .
Now the compressor wheel is 46 trim and should measure 51.7mm across the tips .
Your turbo may be that third version .
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
