  • Replies 1.2k
theres something i was'nt meant to talk about...something im supposed to tip-toe around.....oh thats it! he's the guy you said you did'nt want to talk to Cassi......now i get it! phew, maaan that could have been embarrassing! :headspin: :P ....... :kick: :wassup:
What was with you last night Cassie, thanks for saying Hi...
I said Hi and you completly ignored me. :P
Lies lies and slander!!!
Oh shut up andy i did not that was you, you little liar!!
I'm so sorry hun I didnt even hear you was quiet tired sowee *hugs*.... HI!!!!!!
i got snobbed too but if the person is from um how shall i put this i know a song ...
"take me back to struggle town"
i dont worry about it :thumbsup: j/ks
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
