I hooked up a blender to churn up the air on the entry pipe to my turbo and got 1.21 jiggerwats out of it.....unfortunatley it transported me back into 1935 and i got a blowout on the entry and they only had 20x2inch tyres so i am waiting for the local blacksmith to make me up some new wheels.....hope i can get back to 2004 i really want to hook up my george forman grille to the exhaust housing.......just need to find a way of producing 1.21 jiggerwats again as the battery has gone flat..unfortunatly the only way i know is a bolt of lightning and you never know where or when its gunna strike....Oh wait...the clock tower!
I thought the flux capacitor was actually a Wolf v. 1?
LW.
Na that was only a shitty Motec as you had to use garbage to power it, the wolf you can just use the oil from the george forman grill, so you can have a nice fat free meal and then use the oil to travel forward in time and get magically injectors for ya car :P
NICE!!! :D
I've got a spare "Mr. Fusion" Laying around in the back of my DMC-12 I think, if you couple that with your "Flux capacitors" that might just do it! Just don't forget those babies are polarized or you might rip a hole in the timespace continuum...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
