Hey,
Thinking of heading down with my bro eventually to WSID for some quarter mile action. Anyway just wondering what's the go with helmets - what helmets are sufficient to meet minimum requirements?
Also, is there anywhere you can rent one from? At the moment it's only going to be a one-off thing, I guess I'll see how we go..
Cheers..
https://www.sau.com.au/forums/topic/56223-a-helmet-for-the-14/
For the drags you will just need a Aus standards approved helmet. Most (all?) motorbike helmets will meet the standard. Unfortunately I'm pretty sure there is nowhere to rent one from at WSID, but someone from SAU may lend you one. Personally I'd buy one (well I have). Even if you only use it a few times a year it's much better to have your own. Reasons why:
1. no one elses smelly head has been in it.
2. no one elses fat head has been in it and mishaped the lining.
3. you know that it's not damaged or cracked.
4. no one elses smelly head has been in it.
$300 should have you a reasonable helmet.
Richard
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
