Hey guys,
Just about to puchase an EBC but not exactly sure whats the go with all of them. HKS EVC, Blitz DSBC, Apexi AVCR, Trust Profec-B... My car's never going to run over 1.5 Bar, and i've got a feeling that all the flashy lights and cool displays will eventially become a little bit of a gimmic, so the Blitz is looking the option.
What i'd like to know is peoples experience with the different EBC's the troubles they've had (during install, useage, etc), reasonable limitations of the models, and if the flashy displays have had the novelty worn off after owning it for a while.
Thanks guys!
https://www.sau.com.au/forums/topic/56344-ebc-choices/
Have u had a look at Turbosmart? I have the E-Boost installed which also acts as a Boost Guage. You can have three boost settings and it is very compact and easy to set up. I had mine tuned within 5 minutes driving on the street, by just following the instructions. E-Boost can also be cheaper than some of the jap brands.
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1092554
I've had a Blitz SBC-ID.
Holds boost up top as it learns the boost curve and duty cycle that must be set in order to achieve the boost setting you enter.
You can setup one of the 4 or so channels as a scramble channel that spikes up a little when you first punch it or change gear.
Thats the way I used to have mine set.
Manual mode that would make slightly more boost for the first second or so then the auto mode would take over from there.
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1093166
Had an apexi avc-r... was easy to use and install but had a little boost spiking problem on 12psi plus settings.... Was a little slow to compute the spiking and tune it out...
Must get a dual sol... much better for holding boost...
Got a BLITZ SBC-i-D III now... yet to install... next week
Did all the research and it seem to be really good... Will let u know...
Plus its single din height and 1/2 din wide so it fits a treat under aftermarket single din headunit in a 33...
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1094325
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
