Hey guys,
Just about to puchase an EBC but not exactly sure whats the go with all of them. HKS EVC, Blitz DSBC, Apexi AVCR, Trust Profec-B... My car's never going to run over 1.5 Bar, and i've got a feeling that all the flashy lights and cool displays will eventially become a little bit of a gimmic, so the Blitz is looking the option.
What i'd like to know is peoples experience with the different EBC's the troubles they've had (during install, useage, etc), reasonable limitations of the models, and if the flashy displays have had the novelty worn off after owning it for a while.
Thanks guys!
https://www.sau.com.au/forums/topic/56344-ebc-choices/
Have u had a look at Turbosmart? I have the E-Boost installed which also acts as a Boost Guage. You can have three boost settings and it is very compact and easy to set up. I had mine tuned within 5 minutes driving on the street, by just following the instructions. E-Boost can also be cheaper than some of the jap brands.
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1092554
I've had a Blitz SBC-ID.
Holds boost up top as it learns the boost curve and duty cycle that must be set in order to achieve the boost setting you enter.
You can setup one of the 4 or so channels as a scramble channel that spikes up a little when you first punch it or change gear.
Thats the way I used to have mine set.
Manual mode that would make slightly more boost for the first second or so then the auto mode would take over from there.
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1093166
Had an apexi avc-r... was easy to use and install but had a little boost spiking problem on 12psi plus settings.... Was a little slow to compute the spiking and tune it out...
Must get a dual sol... much better for holding boost...
Got a BLITZ SBC-i-D III now... yet to install... next week
Did all the research and it seem to be really good... Will let u know...
Plus its single din height and 1/2 din wide so it fits a treat under aftermarket single din headunit in a 33...
https://www.sau.com.au/forums/topic/56344-ebc-choices/#findComment-1094325
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
