Motec is fine if you dont want to run over 10,000 RPM (Which is the majority of us)
Dave has had great success with autronic.
Power FC is fine if you like AFM's. (although there is a version that allows you to remove them, i think its the D-Jetro version?).
Personally I would never run a piggy back or SAFC. Not that their bad, they serve their purpose, I would just rather spend my money only once on management.
These are ther only options I personally would opt for. Of course it also depends on your mods/power level.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094531
i prefer an AFM over a map sensor for accuracy and scalabilty without having to retune. Therefore motec is out.
However if you are running HUGE amounts of boost (15PSI plus) then the AFM tends to give incorrect readings or is not that effective, in which case you'll need a map sensor.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094551
Dude its not as if a Motec 'falls out of tune', so i dont know why a motec would be out, apart from the cost.
ever seen an AFM fail and lean out an engine? not nice. Bang for your buck would without question be the Power FC.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094574
I assumed since the motec used a map sensor (which dosen't measure airflow directly and uses on the fly calculations), it'd have to be re-calibrated even if you made a small change like an intake mod.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094827
Shan 15psi of boost is not really HUGE anounts of boost for a afm.
There are cars running 2 bar boost with afm's without problems.
AFM is also good for closed loop and better fuel economy on a daily driven car
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1095078
yeah true 15psi isnt huge for some cars (bad placement on my part). But on my old 180sx whenever we upped the boost over 15 PSI I always got some errors in the AFM. At about 14PSI it seemed to be OK. Then again I was using the stock standard CA18DET AFM, and not a Z32 one or even a skyline one.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1095099
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
