had some tosser pour a drink on my front bar, didnt notice it until i got home...this was in front of a church as well...
Bet it was the priest getting into the communion wine again.
Seriously, just be glad that all they did was pour a drink on it.
I imagine you'd feel a great deal worse if they stole it.
It's gotten to the point where you can't leave your car alone.
Not fair.
Maybe we should start a vigilante group and go out knee-cap a few people ;)
https://www.sau.com.au/forums/topic/56495-not-fkn-happy/#findComment-1094812
i'd be tempted to piss on your car if I saw it too Sameer ;) j/k...
i've had all sorta shit done to my car, its beyond help now... even had some guy stick his chewy on the roof... being a good scientist, instead of tryin to take it off while gooey, I removed the bulk of it, and let the rest dry in the sun before I scraped it off.
https://www.sau.com.au/forums/topic/56495-not-fkn-happy/#findComment-1094968
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
