Changing injector plugs...intake manifold off...any cautions?
Hey all,
I am changing my injector plugs as some are very fatigued...I am going to change the whole lot to be safe, but I will need to take the intake manifold (top) off to get to the back 3 injectors......is there anything I need to be aware of when doing this? I have never done this particular job before and never seen it either.....so just want to make sure I can put it all back together when its done....
Any help would be greatly appreciated!
Cheers,
Corey.
PS: My engine is an RB20DET in a R32 GTS4.
It is possible to get at the injectors with only the throttle body off.
Its a pain in the arse and will leave you with a sore lower back due to bending over for so long.. :)
Everything is straight forward.
Ring nissan and find out what a plenum to inlet manifold gasket is worth. It will probably rip when you seperate.
Change the fuel line hose that attaches to the rear fuel reg while you are there.
Mine was very very perrished.
Another fuel hose that actually had cracks in it as it was that bad was the fuel hose under the fuel filter. Change all fuel hoses it is well worth it.
Shop around. Some places want $10 a meter others want a stupid $20 for fuel INJECTION hose.
I asked for some fuel line hose they gave me the std stuff only to find out later on I was very very lucky for it not to pop. :)
cool, thanks alot guys!.....made things much easier!
I will probabaly just take the throttle body off and do it that way seeing as you guys have done it with not much trouble.
Do I need to know anything special when removing the throttle body?
Cheers,
Corey.
Nope just an allan key... 4.5mm or 5mm from memory... once the crossover pipe is off there are some coolant hoses that run to the bottom of the t/b that you will have to remove (there will be some spillage) and unplug the tps.... I think thats all...
while I had the t/b off I also gave it a good clean with some carby cleaner.. .
i did this two weeks back on my RB20. i didn’t take anything off. all you need is a bit of patience.
start the car, remove the fuel pump fuse. once the car stops running try cranking it a few more times to remove the fuel pressure in the lines
remove the blow-by hose from rocket cover to the plenum, remove the fuel lines from the rail, unplug the injectors, unscrew the two bolts holding the rail and then slowly pull the whole rail with injectors out and slide it towards the front of the car.
as ed g said, don't loose the little metal clips.
when putting them back in, go the same way, just reverse.
i was advised to put some vaseline on the little O-rings when putting the injectors back in so they don’t get damaged. i ended up using some good old water based lubricant. :bahaha: don't use any oil based stuff as it will swell up.
put the fuse back in and turn the key. wait for the fuel line to be pressurised and the check for any leaks. start the car and check again.
LOL...
Thanks heaps guys......I shouldn't have any difficulties with all the info I have now! :-)
I will actually get to start doing it today.....finally! things allways come up, and generally take 3 times aslong to do them...:-(
Cheers,
Corey.
I didnt bother doing that.... just spilled a bit of fuel lol
Just be careful.. the line is pressurised and will squirt out...
I dont actually know where the fuse is in a 32.. mine is in a S13 and I had the loom made the to suit the s13 fuse box
In the boot under on the right hand side under the carpet there is a little grey piece of sheet metal that is shaped to protect a plug.
Unbolt this plate and disconnect the plug.
Thats the only way I found to disable the fuel pump in the R32's.
I was unable to find a fuse. :P
Its a pain in the arse and will leave you with a sore lower back due to bending over for so long.. :P
As I have had to take the head off and just about everything else on my RB20DET recently, and because I am old and frail, I worked out that getting my fold up ladder that can act as a painting trestle to lay on while over the top of the motor certainly saved me a lot of back pain :(
For anyone thats interested, I eventually bought a Metal 1.0mm Grex/Trust Steel Shim Head Gasket from AUTOBARN for $309 and coated it with copper sealant spray both sides before refitting the head.
I was going to fit the standard gasket but could not face another episode of it blowing out the drags again :Oops:
AS I am looking for 250AWKW I thought it may be good insurance!
I do have the workshop man.. but it's at home, you would have to wait until 3pm qld time if you want me to check it... but like I said.. follow joels suggestion
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
