The only research on octane boosters that i have seen shows that they do stuff all. If you really want to change the octane rating of pump fuel you will have to add 10% or more of something like toluene or ethanol.
Hmmm... it looks like you missed these articles then:
http://www.fueltechexperts.com/2008/08/08/...-which-is-best/
20% Toluene +2.5RON
500ml Nulon Octane booster (60l tank) +2.8RON
http://v6supercharged.com.au/workshop.asp?ProjectID=1
Octane booster in action
Quote: "Both the Nulon Pro Strength and the NF Racing Formula rated the best octane boosters in our test... ...Still, both proved extremely effective at increasing octane, even outranking Toluene, which needs much higher levels of concentration."
Why bother running around trying to source and use large amounts of toluene when you can buy a bottle of superior Nulon octane booster anywhere for $25?
The guys doing these tests know WTF they are talking about... more than can be said for some on these forums! :down:
All respect SK but don't the Japanese factory ECU's in the RBs have fuel maps for the 100RON fuel used over there?
In an "untuned" RB (factory ECU) I thought that running a decent octane booster with 98RON local fuel would have benefits
i.e. running the octane that the ECU is mapped for... even more so to avoid detonation with increased boost levels + hot weather?
Clearly it's a different story if your aftermarket or factory ECU is remapped for 98RON
lol you do realise he said that on 21 Jan 2005, 07:18 AM ? :down:
20% Toluene +2.5RON
Octane booster in action]
Yes you're right. I did my research years ago and all the products produced only a fraction of a RON number so I have never bothered. I don't remember seeing Nulon mentioned at the time.
Well I do neither. I am using a petrol from Gull called Force 10 and it is a 98 petrol with 10% ethanol added. It enables me to run more advance and more boost. I have always used it on my car so I cant provide before and after figures. If I were in Aus I would use E85. There is a comprehensive thread on that in the Skyline section by Guilt Toy.
I guess if you lived in an area where you could get only low octane petrol Nulon would be a solution.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
