Sheeezus - I be hot and bored. Anything happening in the Nations capital today? Don't feel like doing the domestics and the music on Teevs is almost over.
Anyone doing anything?
PS. Nice gold pursuit car on the side of the Monaro facing Tuggers way - just around that Model Airplane thingy.
Missed me :)
https://www.sau.com.au/forums/topic/57068-its-hot-and-im-bored/
Id be down for something but I think im still too drunk to drive from last night and its too damn hot to sleep ... meanwhile, serious question, can someome please tell me what teh f*ck is in a long island ice tea? :)
Depending on how many but I'm betting a hangover !
Id be down for something but I think im still too drunk to drive from last night and its too damn hot to sleep ... meanwhile, serious question, can someome please tell me what teh f*ck is in a long island ice tea? :(
Is this how the story goes Nik ?
:) --->:alcoholic--->:rave:---> :inlove:--->:throwup:--->:bonk:----> :coffee:
long island iced teas are potent! all white spirits (vodka, tequila, rum, gin, triple sec) and a dash of coke so it looks like 'tea' :cheers:
i was hungover too...i lay on my loungeroom floor and watched rally, then v8 superstars, then RPM ...didn't move all day lol
im down for something, just unsuccessfully tried to install a boost controller so im keen for a drive and maybe others thoughts on my predicament.
so count me in for whatever
Sowwy Veilside, I waited for a whiles then went to the Jerra Tavern and stayed there filling up on Cold Bourbons and stayed well after the sun went down. Cool on the inside, cool on the outside. If ya still having troubles with Boost controller might be wortha cruise past Ed's for some advice.
I haven't put one on myself (well other than a bleed valve), not really the same thing.
either neither lol :( but its closer to a bleed vavle its a trust phneumatic boost controller with an in cabin dial. but its really just a fancy bleed valve.
i was going to go to ed's at like 4:30 tomorrow evening just before he closes so i could get a bit of advice and then go straight accross to the Jerra pub. but i dont think i cbf hanging around at the pub for a couple hours untill everyone starts turning up.
Go to Ed's and sort it out. You'll be there for a whiles. I'll be down the Jerra by 6:00 getting a meal.
WTF - OC Repeats - You sh!tten me?. I thought perhaps the Gurly boys would be watching 1TH = One Tree Hill...LoL
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
