Massive Skyline Cruise III - Comments/Suggestions/Photos
  • Replies 256
Thanks heaps Erin for the pic.... Car looked sweet today until i got it wet on the way home and dust stuck like glue to finger tips... LOL (Done that a few times)
As for the wheels.....
It was upon leaving i puller over just out side the car park.... (Honest truth was i went into the bushes to have a quickie... LOL no really a leek) When i come back to the car my gf was going back to the canteen to get an ice cream. Anyways i thought id walk down to her and look on the way... Once we got back, a guy with a tyre iron and a jack was just un doing the first nut... I yelled out and he dropped the jack and ran into the bushes with the tyre iron.... Dont know who he was or where he was from... but yeah... not good....
Was not very happy.... Should have been lazy and driven back the whole 100m....
Thats some f**ked up sh1t... Own up you low life!
I knew i should have gone to the toliet....
But damn i really needed to go after i went over the bump at the gates.....
Oh,,,, it felt so good too.... Going in the bushes beside the road is the best....
did you keep his jack? bet if you did in a couple of days somone will ask if any one has a apare jack for sale.
I can't believe somone would do that especially somone from a skyline club :kick:
should of followed him and flogged him with his own tyre iron. if it was me i probably would have lost my temper and beat him up (no good on my behalf) :flamed:
I know he was with us on the ride cause the jack is a skyline jack... Same as the one in my boot.... I threw the lever at him but it hit a branch and i kept the jack....
Come to think about it.... He could have just been an average joe there already and stole the jack and tire iron from someone elses boot????
You guys had better check ya boots... LOL
I still have your jack... but the lever and tyre iron are gone....
col-gtsx, that's seriously some f**ked up sh*t!
at least he actaully didnt get away with it i suppose.. but yeah, if you're on here, i wouldn't be owning up to it if you really want to keep a 'good' reputation....
anyway... good cruise, lots of skylines, lots of pics, lots of sunburn :cheers:
i friigin missed it, i slept in till like 10, and i live an hour away from the start point and have no idea where lake baroon is so i am pissed off:( oohhhh well sounded like a good day anyway, so what was the final figure on how many cars went???
Damn fine effort made by all who showed up on the day, 'cept for the knob who thought a set of VOLK's were easily taxed(F@CKHEAD!!!)......
cheers for a great day,Erin top job!!!!!
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
