Massive Skyline Cruise III - Comments/Suggestions/Photos
  • Replies 256
Very nice work! My car is only in the collage (no video) due to me being at the back of the pack all day, but I didn't do anything exciting so I don't really care :P
Adrian, it's The Reason by Hooberstank
Yeah... as Marc said. Hooberstank.
IT was hard trying to get good video footage because we were at the front. Hence why andrew was at the start going into woodford and at the lake.
If you notice it all.. when the videos change the way the road is going all connect.
And take special notice the drift cat at the begining and again at the end :rofl:
Theres no full shots of my car.. It's the background of a few.
Downfall of having the camera man in your car  I guess :D
I literally have everyones car on video, atleast at some point, and some bits of cb talk :P The vid ends at the traintracks with you saying mr sparkle :rolleyes:
Ill just post up the raw copy when i transfer to computer, mite be a bit big though, theres a kinky section where the gf didnt turn the camera off and the lens makes love to her finger :throwup: lol
Just like to say congrats on making the target of donations for the cruise and well done for the event itself. Looking forward to the next one. I have some photos to share , but am having trouble uploading, so maybe someone could give me some advice, as I'm not very good with computers. I need to make the photo files smaller .Thanks , Denis
www.irfanview.com
Download the program (less than 1mb). Install it, and use it :D
You use the "Resize / Resample" option under the "Image" menu, where it lets you choose from a range of common sizes (you would probably want 640x480 if you want to upload them here, then just send the full size copy to people if they want them) or you can goto a wierd-arse custom size if you want..
Also download the plugins (~5mb I think?) for the ultimate graphics viewer and basic editor. Kicks everything else in the buttocks with big boots. Fast, easy, full of easy to use and easy to access features...
PS - No I dont get paid by them for my spamming :rolleyes:
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
