i,m wanting to buy a pair of cams for my rb25de (r33) head , but the supplier wants to know if its a series 1 or series 2 model . how do i tell . mines got variable cam timing if thats any help .
appreciate your help
post a pic of the throttle body and ill tell you which you have
throttle body is different, ecu is different, turbo is different and a few others
air flow meter is different also
As far as I know they are all same... unless youa re talking about RB25DE NEO...
Neo engine is just fancy way of saying New RB25 block... - in this case there is minor differences.
series one or two means there are cosmetically differnces and interior - just like turbo GTS25T
coil packs ignitor is different on series II i believe
Yep, that's the difference on a DE. Look at the rear of the cam cover, if S1 there will be a black box containing the ignitors for the coils. If S2 there will be no box, instead all you'll see is the 4 mounting studs for the box.
What year is your car? If 93 - 94 then almost certainly S1 engine, if 95 then could be either, if 96+ then almost certainly S2.
you'll also notice the early series 1 has no variable valve timing (like the R32 RB20DE, DET's and the RB25DE that came in R32's) wheras the later Series 1 and 2 do have it.
am still trying to work out for sure . you see i,m trying to buy cams thru nengun and they say there is a difference in crank angle sensor ( how it engages in the camshaft i assume ) . anybody know of any difference or what the difference is
don
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
