  • 3 weeks later...
I think series 8 compliance is between $10 - $12 K
C.A.M. (CANNINGTON AUTO MART) PTY LTD 08 9350 9696 and
E & M UNIQUE MOTORS 02 9648 2778 have compliance and it was spammed out at $5,000 plus tyres by Prestige but them having spare plates is another story, E&M Might.
This link will let you see who has what.
http://raws.dotars.gov.au/rawswebpublic/RA...AWPubSearch.asp
https://www.sau.com.au/forums/topic/57888-rx7-import/#findComment-1140798
  • 5 years later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
