Hey all,
I have a brand new 17" DV171J Mitsubishi Multimedia TFT Display Monitor for sale.
*Backed by a three year parts and labour, on-site warranty and nationwide service centres.*
This monitor is BRAND NEW - NOT one thats been used for 2days etc.
This LCD screen is one of the top LCD monitors on the market and has a very large screen.
Key Features:
*17"/43cm diagonal viewable screen area
*High Resolution, 1280 x 1024 Pixel Thin-Film Transistor LCD Panel
*High Brightness and Contrast - 260 cd/m² brightness and 450:1 contrast ratio
*Response Time - 16 ms (Tr+Tf)
*Auto Adjustment Function for easy installation: automatically optimises the displayed image by tuning it to the characteristics of the graphics signal
*Light Weight – only 5 kg
*Removable Stand with VESA Standard Mounting. Optional ergonomic arms and wall mounting brackets are available.
*Built-in Speakers
*Supports Kensington security locks
Looking for $350 firm
*Note* - This a TOP QUALITY product not a cheap nasty model.
Buyer pays shipping
Reason for sale - need the money to fund car.
PM or email me at [email protected] - Located in perth
https://www.sau.com.au/forums/topic/58063-brand-new-17-lcd-monitor/
  • 3 weeks later...
