Hey guys,
I bought some spitfire ignition coils from nengun, gave them to my tuner to chuck in, and they fit just fine.
Probelm is they dont fire, then with the terminals swapped over they just contiunously arc.
I know there is different packs for S1 and S2 R33 Lines, but my car is definately a series 1, although the ignition setup looks different to my mates s1 93 model (mine is 95).
Is there a way to find out FOR sure if my motor is a S1 or S2, (either visually or on the compliance plate?)and what are the odds of being able to make the coilpacks work in my motor if indeed is a S2.
I bought the S1 packs.
Any feed back greatly appreciated cheers.
https://www.sau.com.au/forums/topic/58197-spitfire-coil-pack-issue/
Nah thats the thing thats different its not there on mine but is on my mates, just did a bit of browsing at http://www.perfectrun.com.au/performance%2...systemframe.htm, according to that i shoudld have the 005 coils, i have the 001's. Is there anyway I can change to an igniter pack to get them to work, i cant imagine the head ache of trying to send them back to Japan?
Sweet ok, where can I get one of these modules? I live in sydney. Any instructions you could give me would be really helpful.
BTW cant send em back, cause the guy from nengun actually emailed me to ask me what series motor I had, he was too helpful, I couldnt shaft the bloke now.
Umm EDIT : not running stock ECU am running EMS stinger.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
