NOT f**kING HAPPY JAN... :P
Some person who should know f**king better just turned up directly outside MY house, in MY neigbourhood, where MY kids were asleep, and MY neighbours kids were asleep, in HIS Skyline and layed 2 black lines up the bitumen in 1st gear 7000 rpm...
Absolutely f**king Stupid!!!
I've told the person (who is on this site) that if it EVER happens again, I won't hesitate to call the cops and give them his name, number, address and plates... There is a time and a place and outside MY f**kING HOUSE at 8.00pm at night is not f**kING it...
Seriously pissed... :(
:headshot:
https://www.sau.com.au/forums/topic/58203-rant/
Now I don't expect this person to own up... Hell knows I wouldn't... I think he would like to, but I think it's for the best if he doesn't...
He's apologised, and that'll do me fine... Just letting others know how I feel and what to expect if it happens again...
https://www.sau.com.au/forums/topic/58203-rant/#findComment-1116895
:P well as for who ever did this GROW the F**k up & think about what your actions are going to do, every action has a reaction thing about that who ever you are
Look at it from adrians point of view he would not do a skid out the front of your place nore would u do one out the front of your place SO why the F**K would u do it out side some one elses place ?????????????????????????????????
THATS JUST :bs!: .
Hope you got the kides back to bed easy adrian
https://www.sau.com.au/forums/topic/58203-rant/#findComment-1116933
It's all good guys... We all do stupid things, and as we get older we tend to think a bit longer before we act...
I was HELL PO'ed when I posted this but I'm calming down now... Those tablets really work! :P
If I was single and lived in a rented house, I wouldn't give 2 sh1ts... But this is my home...
I'm positive the culprit regrets his actions now and it won't happen again I'm sure...
I've done stupid things, he's done stupid things, we've all done stupid things...
Only difference is I got on teh Intarwheb and whinged about it :(
https://www.sau.com.au/forums/topic/58203-rant/#findComment-1116961
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
    • Hi guys,  I just replaced my pads with blue stuff and flushed fluid. The pedal and brakes feel fantastic but I'm getting very slight pedal stutter under any kind of braking. Not every time, maybe 1 in 10 and not under any heavy braking, mostly occurs as I'm reaching a stop. It feels like abs engaging but it's so fast, there and gone in under a second and no abs flash on the dash.  Any ideas what could be causing this?
    • How does dead head help with emissions? Is it being claimed for emissions because fuel in the tank isn't being heated up by being pumped around, hence should condense more? One part that is a negative about dead head is heating the fuel at the rail a lot more (IE heat soaking at traffic lights) and this causing lean outs on takeoff afterwards. If my thoughts above are correct, I wonder how different the tail pipe emissions become with the lean outs vs less fuel tank emissions into a charcoal canister
