LOL...you wont go near maxing out 550cc injectors. Unless the thing had a GT30 compressor wheel when it was rebuilt.
Also external gates are cool, but dont mean more power per say, it can if there is a large restriction in the exhaust housing, it can help with stable boost, so can perhaps stop psi from trailing off at high rpm.
Yeah, I don't reckon you'd need more than 550cc injectors on a stockish RB20
I have seen somewhere on the net a RB20, bored and stroked to 2.4L, with a Greddy T88-33D turbo, making near 700PS. It was used in a RWD slick equiped R32 drag car, from memory it ran low 10's. That used 720cc injectors I think, but I may be mistaken
550cc injectors would be the go for a RB20 if you want to make over 280rwkw, up to that I reckon the GTR 440's should be fine. No need for over 700cc injectors unless you are chasing 600+ HP I reckon
Id even say 550s are too big for whats still a street car... My mate has a 1GGTE (2L 6cyl twin cam turbo) he has whats pretty much a t66 on there now, and 550cc injectors which might hit 40% duty cycle on a good day, the thing has about 350rwhp. Different engine, but not that much different.
I was talking to a friend in Japan last week about RB20's and he was at a HKS drag meet last year where an RB20 powered R32GTST did a 9.9 at 139 mph on radials. It was a 2.4 litre with a T51 ball bearing turbo, not drastically lightened, road registered of course. Punch those numbers into the drag calculator and it says 575 to 600 bhp. That's pretty damn impressive.:(
PS; he has pictures and will find out which workshop it was from.
Hey Chris, or any other 2530/RB20 owners, can you guys post up the rwkw figures at the following rpm ranges:)
Sydneykid - RB25 High Flow
rwkw-rpm
180 7,750
190 7,500
200 7,250
225 7,000
200 6,500
175 6,000
160 5,500
154 5,250
150 5,000
145 4,750
142 4,500
Average Power (4,750rpm to 7,750rpm) - 178rwkw
Roy - TD06-20G , 10cm
rwkw-rpm
165 7,750
175 7,500
180 7,250
195 7,000
205 6,500
209 6,000
222 5,500
216 5,250
198 5,000
174 4,750
132 4,500
Boost comes on strong at 4,500rpm, hits 17psi at 4,700rpm (approx)
Average Power (4,750rpm to 7,750rpm) - 193rwkw
I guessed the last few power figures ie 7,7500 & 7,750rpm so could bve a little less:(
Just trying to get a feel for how they hit boost/drive. Obviously a drive of each others cars woudl highlight strengths/weaknesses...sadly thats not really going to happen.
This is mine from March last year, this is with a HKS 2535 @ 18psi. AFR between 11.4 - 12.0
will attempt GTR cams again in a few weeks and then another tune. we'll see what happens...
rwkw-rpm
175 7,250
184 7,000
200 6,500
208 6,000
200 5,500
192 5,250
188 5,000
182 4,750
175 4,500
Average Power (4,750rpm to 7,250rpm) - 191rwkw
Im noticing a comon thing, everyone says the RB20 love revs, but after 6000rpm they die off. Is this because of the cams correct?
Also if its not toooo hard is it posible for everyone to post boost at all those levels, or even just where boost starts, hits on hard, and full boost please?
Edited my earlier post. Yeh RB20s love to rev based on the mechanics/dynamics of the engine based on the stroked, piston/rod weight etc etc.
The airflow, cams etc means that whilst they can rev hard, they do lose some top end power :rofl:
And thise 2535 results look good, i would of perhaps expected a bit more in the way of peak power aroud 5,750-6,000rpm though?
Well i am finally going to rebuild my engine properly. RB2?. will either be a 23 or 24 depends if i can find some RB26 bits in time or not.
will be using tomei pistons and 1.0mm head gasket.
hi-flowed RB25 turbo (SK comments convinced me)
Going for 240-260rwkws
Date of start is the 01 of March, this year
ohh ditching my four puck for a carbon clutch too.
any suggestions or tips.
IS there a good tuner to re-map the stock ecu in QLD. my guy pissed off up north.
P.S> i have everything else to support my power levels.
hey guys
got a question about a power figure.....
RB20DET
Bottom End
balanced crank
weight matched rods and pistons
Arias 20 thou oversize pistons
all new bearings
Top End
all new valves 1mm oversize
ported and polished head
polished exhaust manifold
match ported manifolds
adjustable cam gears
rest of car
FMIC
3" zorst turbo back
Rebuild VG30 turbo
sard adjustable fuel reg
GTR fuel pump
k and n flat panel with CAI
ecu re-chip
1 BAR of boost
and has anyone does these sort of mods on their RB20 ??
if so what rwkw did you get
i am about 2 weeks away from that list on my 32
My tip would be to pick up an R32 RB25DE head use turbo valve springs and check the valve seat tension, R32 RB25DE bottom end (r33det if you want the oil squirters) forged pistons and rebuild that.
Possibly even use the GTR Rods and crank in that? 2.6ltr maybe 87mm pistons to bring it out close to 2.7ltrs.
Work out the price for both and decide.
The reason for the R32 RB25DE head is that you are able to use all the stock Rb20DET bits and bolt it on. You will only need the R32 RB25DE inlet manifold (which looks exactly the same as the RB20DET one but internally is larger). Bolt the rb20det plenum on the inlet manifold, use the rb20det center coil cover and you will have a motor that looks identical to a RB20DET.
Unless the head is pulled off the new hybrid rb25 there is no way you can tell it is a 2.5 or 2.6ltr depending on the crank and rods you use.
And remember, when you purchase a new block it has no engine number on it. :cheers:
1. i had a RB25de in it before. swapped it.
2. i don't want a RB25 or 25/30
3. RB24 will go harder sound better and cause i just wanna.
4. i am not a big fan of sheep
You gota admit tho a nice peice of lamb with a nice sauce on it isnt too bad!
You asked I replied....
Why do you worry about being a sheep?
The motor will be more reliable make more power everywhere, the turbo will be pumping cooler air as less boost does = cooler a charge.
If you know how to read compressor maps you will know exactly what I am talking about.
The Rb25 head over the rb20 head requires some where around 5-6psi less boost for the same or similiar airflow.
lol... It makes me laugh when people think doing some thing should be ignored because it would be considered sheepish.
Who cares.
When I built up the RB30 it wasn't to be 'Different' it was because it gave me the driveability characteristics that I wanted, lots of mid range and the potential for awesome top end with a decent set of cams.
The RB20 even with another 300cc's really doesn't float my boat, but then again, I could keep telling my self 'its different' when i'm waiting for that 250rwkw turbo to spool up hit hard and break in to uncontrollable wheelspin at 5000rpm.
:rofl:
As I said.. You asked for a suggestions.
No need to get all cowish over it. :)
Im bringing my car over the first wek of Feb, fingers crossed with a re-tune and new exhaust ill be pushing out close to 240-250rwkws:) Maybe we dont need the 300cc, but hopefully we dont have wild wheelspin either:)...and fingers crossed it lives and the old $600 RB20 provides plenty of fun:)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
