11.7 and 116 mph = ~250 rwkw (that's on a roller dyno)
If it is a hub dyno, add 15 rwkw (no wheels or rollers).
265 rhkw (rear hub kilowatts)
Note no mention of camshafts:cheers:
So what sort of camshaft/timing do you think this engine setup has. I would be surprised if this is radical, may be just an improved standard setup
Turbine
sk, the hr31 irs is very difficult to control. No matter how much wheel alligning you do the design of the irs still see's the rear tyres half of the ground. Every import 31 has this problem.
Took it for a proper drive for the first time since I got the car back from the tune, and its developed a nasty missfire as soon as it hits boost. Im thinking ignition (again) since the back of the car was covered in fuel when I got back... time to bring the plug gap down yet again.
sk, the hr31 irs is very difficult to control.  No matter how much wheel alligning you do the design of the irs still see's the rear tyres half of the ground.  Every import 31 has this problem..
This one works great;
They are no more difficult than any IRS with struts. The trick is to find out exactly how much it is going to squat, I use a video camera and cable ties on the shock shafts for that. Once you know, then you can simulate it on the wheel aligner by jacking it up and down with the rear springs out. You remove as much dynamic camber change as you can with the offsett bushes. Then you set the static camber so that the tyre contact patch is optimised at full squat. It's pretty simple really.:(
we aint all on race team budgets remember :P
You're kidding, right? Our budget wouldn't buy the paint job on an Autosalon car. It's not about how much you spend, but what you spend it on. An example;
Hey mate, for $700 I can get you lots more power, enough to improve your 1/4 times by 0.5 sec. How fast would you jump? :wassup:
Compared to;
Hey mate, for $700 I can do a wheel alignment that will improve your 1/4 times by 0.5 sec. Now how fast would you jump? :kick:
We have to make that sort of decision all the time, what do we spend the limited money on to get the best result. Engine power bragging rights are pretty worthless, it's all about how long it takes to get from the start of the race to the end of the race.
:cheers:
Hi all , have to agree some mods forced by limited budgets can be very effective . Some time back I had DR30 IRS grafted into a Bluebird and remember thinking the crossmember bushes were too soft . The budget fix was to drop the rear end out and fill the gaps in the rubber bushes with of all things stickerflex . This stuff has very similar consistency to the rubber and is the cheap way to get a "works" style bush that still has some compliance . I have seen a few HR31 IRS rear ends and their X member bushes are REALLY soft . This will not help with tramp or alignments .
I got the car back today and it did 271rwhp@16psi .It was'nt tuned in kill mode but it's safe.I used to get like 90 knock all the time with the old tune but now the most is 35 and thats raping it.300 would be good to have so I'll see what happens.
Nice, it wil make 300 easily with 19-20psi:). How does it feel on the road?
Can you post up a link to your dyno sheet (and mine.. I lost the link), be interesting to see how much better your power curve looks.
HKS GT2535 turbo
Stainless exhaust manifold
R32 GTR intercooler
Z32 afm
Apexi pod
R33 GTR injectors
Greddy profec b boost controller
3inch dump pipe,3inch mild steel mandral bent exhaust
Bosch 040 fuel pump
Nismo adjustable fuel regulator
Apexi PFC
16psi
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
