Well just picked up from the latest tune getting there but not yet still getting hot at the moment guess i need to get that new radiator and still recons exhaust is restrictive but I like it the way it is so this is gonna have to do for now still its not to bad check out the graphs and opions welcome .Graphs show both high and low boost
Cheers Peter
lol.
I came across one of 'those' people the other day at Sprint Autoparts.
He was dribbling on how he had this R32 GTS-T.
166rwkw on 12.5psi, malpassi fuel reg, std ecu, exhaust, fmic.
He said he ran a 12.8 at 110mph with a 60ft of ~2.2. lol
He said if he got the launch sorted he would be close to the 11's. HAHAHA
What a knob head. Seriously, so full of him self.
ADPSI, which holds the current highest out put for an rb20 in aus, will be back out on the road soon, with even more power now. Its made 500+rwhp previously.
My 20 cents worth, it's not an RB20 if it has an RB26 crank, 3.5mm oversize pistons and RB26 rods. That's an RB24:cheers:
Legend01  besides shim clearances did you have any problems ?  no spring binding etc
i have a pair ready to roll
cheers
Hi MrMayhem
Being hydrolic there was no problem with shim clearences had the head done port and polish new standard valve springs and the cams just bolted straight in no problems with clearences with the lobs touching the head all lobs cleared fine though i must state that the hks cams 264 duration 9.0mm lift im using are heal and toe which means the take a little of the heal of the cam and add a little to the toe to get the lift required and had no trouble that im aware of with valve springs binding but only been reving it to 7500 rpm
Cheers Peter
Hi MrMayhem
                                                          Cheers Peter
Gday peter - spring binding doesnt depend on RPM - if springs dont biond when you spin then engine over by hand, it wont bing at 9k rpm
cheers,
Matt
got my car dynoed today
190.7rwkw @14psi
has run 13.6 on 12psi 102.4mph
have had a max of 104mph
next mods:
suspension
ex cam gear
chip ecu
im not aiming at any great figures, instead a great road car with plenty of response.
RB20 forever!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
