yeh looking forward to getting 200+ with no major mods
there isnt a whole lot left in the R33 turbo im afraid if your on the 14/15psi mark now with it.
1-2psi more and i think thats where the power increase will stop (if it isnt there already)... and where the wheel spitting will occur :P
Id say this is true. Last time i was on a dyno i tried 1 bar = 183rwkw and 1.1 bar = 185rwkw
Ok, just posting a brief update on my car.
Took it out for the cars and also my first quarter mile action at Heathcote.
Really really bad axle tramp and wheelspin. The car was shaking so hard the boost gauge rattled off the dash! LOL. Couldnt do better than 2.5 60 footers. My initial plan was to crack 13s and 110mph. But just missed out on both. Ran 14.2/3 every run and 108-109mph.
Popped my drag cherry and will attack calder asap.
Ah yes R&D on a RB20 to make big power is good. makes you use ur brain than just opening your wallet. will make the end result (if all works out lol) more rewarding.
When is this thing goign to be finished. If someone can get decent numbers out of an RB20 then i may bother sinkign a couple of hundered a month into my spare RB20, though i dont see my TD06-20G ever cracking 270-280rwkws no matter what head/cams mods i run:blink:
lol yes ROY this build has been going on for a while, but ive turned a car i used in a wedding into a drift machine and that takes money. so stay tuned. i was going to do the engine first but decided to start at the rear and work forward. once i start on the engine it will only take a few weeks and it will be back in and making some numbers. I can pretty much promise you it will crack 300rwkw. its just a matter of having the spare time and money.
Close to the 200rwkw mark. Got a tune the other day and got 255 rwhp @ 1bar. Was hoping for more like 290ish but will have to wait for new fuel pump to go in! hopefully next weekend.
Has HKS 2530
32 gtr cooler
550? injectors
z32
lumpyrom retune/remap
Had magor ping before tune and had troubles getting it to the stage where it wouldnt. Was told fuel pump should cure this so am putting in bosch 023. What sort of boost are others with a 2530 running? I was thinking of going to 1.1 bar but would like to see 300rwhp.
r32 rb20det (late model) swapped into USA s14 chassis
RIPS intake mani
tomei 260/8.8 cams
greddy cam gears (currently zeroed out)
gt30r turbo with .63ar turbine
550 supra injectors
fmic 24x3.5x6
hks exh mani and gate
retuned ecu for injectors and z32 maf with tweaked timing map
from the looks of it the lag is proly caused by the lean condition on spool up, once i get my biki rom from bad biki life should be much better.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
