hehe, yeah there is a place here stateside that will test oil for whats floating around in it......
yeah im using the emanage to fork with the maf signal (which it does do well) but since the ecu has an agressive timing map (actualy on the ecu) forking around with the maf voltage makes it feel terrible if i do it too much.
if i dont use the emanage to correct it runs too lean due to the timing map...... so its a catch 22 untill i can get the biki rom where i can see where i am on the maps.
there isnt that much correction on the map like +10 pts which isnt too terribly much but its enough to fork with the signal enough to really make it feel weird.
from what it looks like i might be able to get full boost at 4k assuming i can add fuel in the right spots (which i cant do with the emanage right now) and it should have a fairly beast/wide power curve if i can get it that way......
i will let you guys know my results tho for sure, because once the car spools its frightenly quick.
OK, so what you are doing is richening up the A/F ratios with the EManage, this retards the igntion timing and so it feels sluggish. Unusual situation, 99% of the time we are trying to lean out the A/F ratios by bending the AFM output voltage.
What I would do is increase the fuel pressure (adjustable FPR) so that I didn't need the EManage to make it richer. I would adjust the fuel pressure for 12 to 1 A/F ratio at the max power RPM. Then use the EManage to tune the other RPM load points. This will remove the need for large amounts of voltage bending by the EManage and retain some semblance of normal ignition timing.
If I couldn't get the injectors to flow enough at the higher fuel pressure to achieve the 12 to 1 A/F ratio , then chances are the injectors will be too small regardless of what ECU I am using. So upgrading the injectors is the next step.
Hope that was of some help
:blink: cheers :D
Hi Guys Ran my R32 gtst with a friends R32 both rb20dets just thought you'd like to see the results first time ive run at the drags in over 25 years and yes im on old fart but going fast never gets outa your system anywat clutch started slipping on the next runn so had to call it a night might have gotten better with a bit more practice
Cheers Peter
Hi Cubes
Power is 238kw and running rb25 box and the tyres are m/t et street drove there and back with them on
Yogi000
the turbo is still the prob at the moment runs out of flow by 6800rpm new turbo on order Gt3040r that will improve the top end hopefully
Cheers Peter
I cant read the time slip???
Time for some reading glasses mate!
Try this one, I touched it up a little
Great times BTW, one tough RB20!
Edited by Chris32
Damn...im running more mph but 6 tenths slower...lol i can t drive my car off the line for love or money:(
The answer is;
:P Cheers :D
Hi Guys
both cars are R32s both rb20dets mine's running the et streets the other was running Hooser semi slicks
Roy
I ran higher mph on street tyres but 1.5 second slower times
i think it might have something to do with tyre dia as the m/t's were 26x10.5x16 "si just fried the street tyres 1st ,2nd and 3rd
Cheers Peter
Edited by legend01
Hey legend would you mind posting up what modifications you've done to your car to get it to 238rwkw? And also your mates car if you know.... those are some awesome times. Very impressed with that 60ft time from a rwd.
Please run an 11 on a stock RB20:)
I cant recall reading if you are using the std gearbox? What clutch and diff is in the girl.
After the last track day in late October i want to hit the drags, my housemates poo RB25 thingie ran 0.1sec quicker then me, (but 3mph slower) cant have the quickest car in the house being an RB25:)
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
