LOL...farkin spreadsheets :D I was bored at work and trying to do it covertly. Im half pissed and bored at 12.30am in a hotel...ill try again but cant guarantee the result will be any better considering the state im in :D
that 4th gear comparo for road speed to revs...cool, i need my spreadsheet on my laptop to work it out accurately. What sized tyres have you assumed, (tyre circumference)???
i actually was going to give it a go as well but for some reason this laptop does not have excel on it... random
um, my tyres were 255/40/17's and was about 36.6, but i just worked out my mate with 235/45/17's was around 37.6
somewhere around there so make it around 37 and u will get if fairly accurate
How is that? It seems i had changed the scales to try and move the boost curves away from the power plots, and it all went bad from there...but i think this looks better.
Yeh its pretty easy to do the conversion, but im lost without my laptop, i have all the gear / diff ratio, tyre sizs etc on it.
Cerbera, if my understanding of your Apexi turbo is right, you have the P25 exhaust housing, which is about a 0.96-1.01 A/R housing.
Would love to see your results if you used the smaller P22 housing, dont they also do a P20 or something (IHI use mm instead of inches so i think you just divide the PXX /25.4 to get an equivelant Garrett A/R, so P25 is 25/25.4, so about 0.98 A/R)
The P20 is about an A/R size of 0.78 which would get that thing boosting way earlier and harder
im unaware of how the scale of the apexi to convetional garret a/r works but just looking at the housing it is at least as big as a 0.8a/r
my turbo came only in a p25 or p22 housing so im unsure if you would be able to connect a p20 housing as the actuator mounts may be not suitable ?!?
i do agree with you tho, the p22 housing would probably be much more suitable to the 2l and i doubt i would loose much top end if any
only problem is finding a housing to borrow or buy for the test, apexi turbos dont seem to grow on trees :D
Edited by Cerbera
Yeh , i had a bit of trouble finding the smaller housing on the TD06. But im sure that IHI use metric where as Garret use Imperial, so P22 woud be 22/25.4, so about 0.86.
Ill have a look around tomorrow night. Based on the changes i saw in power with the smaller housing...your thing would be a hard to beat setup that s bolts to the std manifold. Be interesting to see of you crack the top end your hunting after the next round of tweaks
next round of tweak is going on as we speak :D
new ignition is already on, but still the miss
fuel pump died on friday so hopefully replacing it with bosch 040 will maybe fix the miss as it may have been the rail running low pressure top end
also tossing up the idea of welding a external gate onto the standard manifold for better boost response and control as well as to lower the backpressure in the exhaust manifold top end
Edited by Cerbera
much better :)
looking at carl h graph makes me get bad ideas about upgrading to gt30r love and some cams
its really not that laggy for the extra power
hahaha, oh you know you want to join the darkside.
also keep in mind my engine wasnt in good nic (140 psi HOT! across all cylinders) so on an engine with higher compression its very possible it will come on earlier and even harder than she did in mine.
gt30r is very well suited to the rb20, almost as if it was designed for it......
I found this plot on NS of a TD06 on an SR20DET with Greddy TD06 L2 20G, Built motor, Hks 256in/264ex, Hks cam sprockets, Autronic, Msd Cdi, Bosche coils, Blitz 850cc, Bosche fuel pump, Blitz intercooler, Blitz stainless pod, Blitz Sbc iD.
Was havign a sticky beak as im playign with motor combos at the moment (will probably not end up doign any of them) and all this talk about SR20DETs being more responsive etc etc. Plus if an RB can be put in an S13 so easy, then surely the SR is a relatively straight forward swap. Combined with the weight savings, cost of 4 rods/pistons etc, and the much talked about lack of torque of the RB20, against the SR superiors supposed ability to spool turbos
Phew, get what im getting at :( LOL a tweaked SR20 appears to be no more repsonise then a std RB20 with the same turbo setup. So the first comparison i found doesnt do the SR20 chitter chatter much good
Im hunting around for a few equivelant turbo SR v RB20 comparisons. It appears that the weight of the average S13, combined with the gearing is probably proves more a factor then the additional stroke fo the SR20 in making it a more lively street car.?!?!?!
So Round 1 with SR20 vs RB20 with TD06 is a draw :)
Perhaps a win to the RB20 considering it doesn thave cams :)
Yeh but from the results i have been looking at, the whoel SR being ouncjier then the RB20 is a crock. The RB20 doesnt have any trouble matching the power of similarily modded SR20s.
Be interesting of more ppl plotted torque on the right axis rather then A/R or psi
I'm in two minds at the moment... Whether to swap to a 25 if(when :() my 20 blows, or to keep the 20 and work the tits off it.. Its for drifting - a few of the guys over here have bulk power coming from 25's on standard internals.. so I dunno what I should do...
Roy, I think you'll find the S14/S15 SR20DETs with VCT spool the turbo a fair bit quicker than the S13 donk thanks to the added overlap in the midrange. Disable the VCT and the turbo becomes suprisingly alot more laggy...
Edited by Busky2k
LOL... then i want one of those HKS vatiable cam timing RB26 kits for the little RB20:)
Will be interesting to compare, a friend had a 230-240rwk S14 with Nizpro setup and its not overly different to my car to drive..though he did say his car did have a bit more urge if you were crawling up a hill at 2,500rpm in 3rd, so under load or light throttle could be worlds apart
With regards to off boost accel.
Maxx's r33 RB25det felt as if it had the same low down urge as his s15 sr20det.
HOWEVER, the sr20 didn't feel as revy and the power band felt shorter due to the shorter 6speed ratio's.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
