boostn32 are you goin to be running standard gearbox in your new setup. If not what are you going to be running? Thanks
i have 2 rb20 boxes that need new syncros on 2nd, not worth fixing so will be doing the 25 box conversion once i have broken both 20 boxes lol :lol:
ok LOL i dont think you would have too much of a problem breaking them at the power your after. true?
Well i got my engine pulled out today they will open the old fella up within the week. Im also in the hunt for 300rwk out of the rb20 in my s13. Any of use guys know how strong the CA. diff is ;) Maybe i might be better off asking that question at ns.com
You wont break the diff, if you have the standard center i recomend replacing it with a mech 2 way.
makes sure you get the block modified for extra oilling on the main bearings and use RB26 bearings, i used ACL Race series, they have 4 oil holes instead of 1 they will help the crank survive 8500 rpm+
Is that a straight fit? What engine modifactions exactly, , do you recommend for oilling improvement? Do you also use a n1 oil pump or other aftermarket?
Edited by ivosp
yes the bearings fit as the mains on all rb cranks are the same as in diameter, i forgot to take pics of the modified block, was to keen to put it together. but what the machine shop dose is machine a grove about 2-3 mm deep and wide where the main bearings sit so there is like a resevour of oil under the bearing and since there are 4 oil holes in the RB26 ACL race bearings they allow more oil on the crank.
I just used a R32 RB26 oil pump. i will be putting a shim under the pressure releif spring so i get about another psi or so of oil pressure.
heres a good link for anyone wanting to find there compression ratio
http://www.csgnetwork.com/compcalc.html
Edited by boostn32
hmmm well i had my car tuned yesterday... and was very disapointing..
its a rb20det with..
3 inch exh
k&n pod
Q45 afm
walbro 255 pump
599cc injectors
modded plenum
modded cams
lightly ported n polished head
ss exh manifold
turbo turbonetics 60-1 t3/t4
44mm tial waste gate
turbonetics godzilla bov
fmic
and apexi pfc + boost controller
and it made 320hp at the wheels on 16psi :P
does anyone know why its making so little power??
Cheers
i had mates s13 on the dyno the other day and it made very disappointing performance also, tuner put it down to the walbro fuel pump, apparently they're not soo great and he says some work better than others but a lot of them can't flow much past 260ish rwhp
this is for the 450hp model
mate will be upgrading to a bosch 044 and getting some cams soon
you have any pics of your engine bay???
3 inch exh
k&n pod
Q45 afm
walbro 255 pump
599cc injectors
modded plenum
modded cams
ss exh manifold
fmic
Cheers
I think thats pretty good power i have alot of the same mods and a few others and u made the same power as mine and i was running 20psi boost
Cheers Peter
couldn't say if that's the problem dude, but tuner reckons that's the problem on his car
i was also told sr's dont' like making power after 260rwhp without cams..
glad i got me an rb20 then:)
just wish i had his turbo and other bolt ons hehe
3 inch exh
k&n pod
Q45 afm
walbro 255 pump
599cc injectors
modded plenum
modded cams
ss exh manifold
fmic
Cheers
dude,
320rwhp = 238rwkw. that ain't exactly low power for 16psi. that by my standardsis a good effort.
how does it feel when u drive it on the street?
if possible, show us your power graph/AFRs.
yeah i gotta agree, its just a t3/t4 hybrid thats probably most i've seen from one on rb20, mate had about 300 on his and still managed a 12.55 in heavyish r31
example i used being my mates car is a hks 2835r on 1 bar
only 255rwhp
i plan on beating that using my neo r34 turbo on my redtop 20 lol
Edited by Bunky_r31
3 inch exh
k&n pod
Q45 afm
walbro 255 pump
599cc injectors
modded plenum
modded cams
ss exh manifold
fmic
and it made 320hp at the wheels on 16psi :(
Cheers
Its not shabby power, bit looking at the compressor map of the 60-1 it should maek more power.
Any dyno sheets? What did the tuner say about the performance...i would maybe consider putting a std manifold back on. If the flow distribution is worse then the std manifold, wouldnt that mean a particular cylinder may lean out before the others meaning the end of all the fun>???
I dont know...but 238rwkws is pretty damn good for only 16psi...whats it like to drive?
320rwhp isnt too bad at all for 16psi in the scheme of things. I have a Garrett T3/T4 and when tuned at 16psi made 235rwkw. I wasnt dissapointed, I was actually very very happy. Why are you dissapointed? What power did you think/told it would make?
For comparison, when boost was upped to 21psi power climbed to 285rwkw from a turbo factory fitted to a car in 1987 so you could even make more.
For 285 on an RB20 you'd think it was asleep untill over 5,000rpm but it makes the 21 at 4100rpm in 4th on the dyno.
As mentioned by above peoples:
Put up some dyno graphs, hopefully with power vs boost.
"ss exh manifold" what type? got a pic?
Hows it drive?
Jayson........
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
