Hey guys i was wondering if anyone has a basic DIY for changing the clutch and if they dont just some basic things to look out for. I have a feeling that my thrust bearing may need replacing but obviously to get to that i need to get to the clutch. So yea we did it on my sr20 before but that seemed alot easier than what this will be. anyways if you could help out i would appreciate it
oh its a rb25det from a s2 r33
https://www.sau.com.au/forums/topic/58320-diy-changing-clutch/
It's really easy providing you've got a hoist (for g/box) and IS time consuming ..
Slightly more awkward than the SR as theres a little less room to work around the bell housing/bolts but .
Disconnect your battery
Start with the usual and remove the gearstick (circlip) then unbolt the prop shaft and have a catch can handy for all the box oil that will drain out of the rear, you might want to re-use this oil also.
Loosen the frontpipe off the exhaust system also which provides a little bit of leaverage to allow the engine to rock.
At this point I'd advise using your hoist under the gearbox to support the weight while you remove the bolts around the gearbox mount. Then slowly, lower the hoist which will allow easy access in undo-ing all the sensor wiring off the gearbox. Use a small flathead screwdriver for this as they can be very hard and brittle after many years in the land of nippon. :rolleyes:
At this point the hoist should be supporting the entirety of the weight apart from the bell housing. Undo all the bolts off the bell housing and push the starter motor aside.
There is limited room to actually wiggle the box out like I mentioned before so be careful with this and do not force it. You'll find that it'll be necessary to slightly roll the box around a few degrees to clear the starter motor housing of the firewall (on the bell housing as you probably know).
At this point the box should literally drop out slowly as you lower the hoist. Then simply roll the hoist back to remove the box completely and presto, it's done.
If you want any specifics let me know :P
hey jengi thanks heaps for the advise that sounds like the majority of what i needed to know :rolleyes:
yea taking the sr20 apart was a bit of a bitch the way we did it eg no hoist lol we wont be making that mistake again.
and once again cheers Jengi really appreciate the help
I have done a handful of skyline clutches on the ground. I just advise anyone of concidering doing their clutch without a hoist. The box is quite heavy and large on a skyline and it really just isnt worth the pain and well danger of doing it under the car, from now on i will only do them on a hoist with a trans stand.
I do them on the ground all the time , this is what i do .
Jack the car as high as possible , put stands on all corners then do all the unbolting as jengi posted , i let the gear oil out of the box first though . When all the bolts are undone , i leave a couple on the bellhousing , i use a trolley jack , on the gtr or any 4wd i tie the the box to the jack ( use chain ) ,undo the last 2 bolts on the bellhousing , then lower the box to the ground . If i have clearence problem ( getting it out from under the car ) , i either get another jack and jack the car heigher or i drop the box on a little creaper like trolley and bring out like that .
Of course if you have a hoist and a transmission jack its heaps easier .
  • Thanks 1
  • 4 months later...
I'm thinking of changing my clutch in the next few weeks. Few quick questions...
Do you need a special tool to align the clutch?
How many litres of fluid does the transmission need?
How long would you expect it to take?
You do need something , a broken shaft will do the job .
Trany takes about 3.8 lts .
Time depends on your skills and tools you have .
Done this before.... 1st time was piss when we didn't change the clutch. As soon as you move the clutch plates and have to realign them and its multi plates it gets tricky.....esp when ur doing it on the ground. We had trouble getting the spline to go through the plates as we could'nt get the angle right.... got the old man to come up and help and went through 1st go :confused:
Cheers.
Also, I'm thinking of just changing the clutch plate. Is this worth the effort or should I replace it with a whole new kit? I dont really want the pedal to feel heavier than stock...
Why you want to change the "just the clutch plate " , is the clutch slipping ? if yes dont bother do a complete job , if no dont bother taking it out until it starts slipping .
by clutch plate do you mean the thrust bearing ??? if so i would do it thats the only reason i was going to drop the box out to replace that but i have since realised it is not worth the effort.
Thrust bearing is just that a bearing , clutch plate is the round thing with the friction material on it , so no 2 different things .
Obviously its slipping. Even in 5th at 100km/h, before it makes full boost, it slips.
After doing some reading it seems that changing just the clutch plate provides more 'bite' while retaining the factory feel of the pedal (and its cheaper). Is this true?
If it slips , bite the bulet take the box off and replace the whole thing .
You dont have to use a different pressure plate , you can use a Nissan one if you like ( i wouldnt though ) .
By just changing the clutch plate now , you are going to have to pull the box down again to replce the pressure plate , clutch plate and thrust bearing very soon.
The reason its slipping worn clutch plate and pressure plate or to much power if not stock.
  • 1 year later...
ok sounds hard but eazy at the same time to change the clutch.
atm i only have the money to get a decent clutch and dont have money to pay someone to install a clutch.
when dropping out the gear box does it slide off the drive shaft or dose it stay connected and it just dropps down to give you access to the clutch??
if someone has pics of what to undo would be help full or a site that gives more details
thanks
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
