  • Replies 41
I am getting some printed for James (as he's a top bloke lending me the car) and I'll probably bring them to the next meeting.
As for high-res photos, I might release a few as SAU wallpapers or something. Looking forward to working on the calendar so stay tuned for that.
https://www.sau.com.au/forums/topic/58439-i-stole-golgo/#findComment-1120028
What camera was that with? What settings etc?
Nice shots ;)
Not too sure how you did the first one, windows closed, drivers side, no back window to hang the camera out of... was it attached outside the car or something?
https://www.sau.com.au/forums/topic/58439-i-stole-golgo/#findComment-1120464
Nice shots :)
I believe Greg uses a Nikon Digital SLR...
Looks like that Manfrotto camera mount is going to good use Greg :(
https://www.sau.com.au/forums/topic/58439-i-stole-golgo/#findComment-1120663
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
