hey guys, i got some stuff for sale
- JIC front negative upper link R33 GTST - $250 (these are Y27,800 at perfect run which is $344.418aud exluding freight and handling)
- JIC Magic tension rods for R33 GTST - $170 (together with negative upper link $350!!)
- HKS mushroom pod filter needs new element - $60
- A'PEXi N1 coilovers, just been rebuilt $1150
- Cusco upper arm for R32 $170
- Twin blitz BOVS with adaptor for R32 GTR $SOLD
- HKS Style dumppipe for S13 $SOLD
- HKS Pod with long HKS adaptor tube, needs element $80
i can COD any of these parts anywhere over australia!
thanks
arch
https://www.sau.com.au/forums/topic/58763-heeps-of-bits-n-pieces/
- JIC front negative upper link R33 GTST - $200 (these are Y27,800 at perfect run which is $344.418aud exluding freight and handling)
- JIC Magic tension rods for R33 GTST - $150
- A'PEXi N1 coilovers, just been rebuilt $1200
- Cusco upper arm for R32 $190
- Twin blitz BOVS with adaptor for R32 GTR $280
- HKS Style dumppipe for S13 $130
thanks
arch
prices dropped!
13_devil: These got rebuilt about 2 - 3 weeks ago, you can even see all the bushes are in brand new condition. These will last as long as a brand new set.
Mr GTS4: Im not to sure if they will fit i would most likely think they would, can anyone clarify this?
thanks
arch
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
