hey guys, i got some stuff for sale
- JIC front negative upper link R33 GTST - $250 (these are Y27,800 at perfect run which is $344.418aud exluding freight and handling)
- JIC Magic tension rods for R33 GTST - $170 (together with negative upper link $350!!)
- HKS mushroom pod filter needs new element - $60
- A'PEXi N1 coilovers, just been rebuilt $1150
- Cusco upper arm for R32 $170
- Twin blitz BOVS with adaptor for R32 GTR $SOLD
- HKS Style dumppipe for S13 $SOLD
- HKS Pod with long HKS adaptor tube, needs element $80
i can COD any of these parts anywhere over australia!
thanks
arch
https://www.sau.com.au/forums/topic/58763-heeps-of-bits-n-pieces/
- JIC front negative upper link R33 GTST - $200 (these are Y27,800 at perfect run which is $344.418aud exluding freight and handling)
- JIC Magic tension rods for R33 GTST - $150
- A'PEXi N1 coilovers, just been rebuilt $1200
- Cusco upper arm for R32 $190
- Twin blitz BOVS with adaptor for R32 GTR $280
- HKS Style dumppipe for S13 $130
thanks
arch
prices dropped!
13_devil: These got rebuilt about 2 - 3 weeks ago, you can even see all the bushes are in brand new condition. These will last as long as a brand new set.
Mr GTS4: Im not to sure if they will fit i would most likely think they would, can anyone clarify this?
thanks
arch
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
