hey people, lookin to drop a RB30 in my R30 hatchback as the L24 is about to shit itself and is costing me a fortune in fuel (400k's to a tank)
anyone know anything about this conversion.
things i need to know is
- will the gearbox bolt to the RB30
- can i use the same clutch from the L24 on the RB30
- can i use my current diff or should i put a R200 as the hatchback has IRS
- can the RB30 powersteering pump be used on the R30 without stuffing up the rack
- what engine mounts do i use (i was told that u can drop it straight in but the intake plenum sits too high so to reslove this problem drop R31 mounts in) is this correct?
answers to these questions would be greatly appreciated and if there is anything else i need to do/have please do tell.
also would i have to upgrade brakes or have a engineer go over it all?
thanx heaps
Ivan
https://www.sau.com.au/forums/topic/58870-rb30-in-r30-hatchback-need-help/
Is it a similar car to the Z?
If so, the L series sump has the bowl at the rear, the RB series has it at the front. Need a new sump if this is the case, I am importing some brand new 200ZR rear bowl RB sumps for my conversion.
L series gearboxes will not suit the RB without bellhousing mods, not worthwhile when RB20 boxes are as cheap.
I thought R30's had long nose R200's.
L24E in R30 has sump bowl at the front, which is the same as RB30, so that's not a problem
No - as suggested you need to change to an RB gearbox, or put an RB bellhousing on your existing GB.
Not totally sure on this one but chances are high that the clutches are the same or v similar. In any event I'd recommend chucking in a new clutch while you've got it all pulled down and in that case you'd get the RB30 type.
Your R30 uses R180 diff. These are reliable up to 250HP or so. Unless your planning big mods I wouldn't worry about it
You aren't going to have a whole lot of choice. L24E PS pump won't fit RB30 block, so you'll have to use the RB30 type if you want PS. I would say it should work OK, but might be worthwhile to check if there are any differences in operating pressures.
Problem here is that the L24E sits at an angle in the engine bay, and the existing mounts are designed for that. You may have to experiment with different mounts to get the best fit. I don't know of a single answer for the issue, but have heard that some have resorted to bolting in the R31 cross-member to solve the problem (but I gather it's not quite 'bolt in'..)
- also would i have to upgrade brakes or have a engineer go over it all?
You need to check with rego authorities about engineering req's. In Vic it would definately require an engineering inspection.
I'm interested in the same sort of conversion for my MR30 Hatchback, except I have the 4spd Auto box. Can I use the stock box or is it the same problem as the manual box?
I can imagine the conversion isn't cheap, but how much would i expect to pay for all of the parts, including suitable brakes and auto box?
My L24E is also costing me a lot in fuel and isn't too healthy right now, is there a simpler/cheaper conversion using a bigger or more powerful engine than what I've got? the RB30 sounds pretty expensive.
Brake upgrade easy DR30 stuff back and front . If you need some bare DR struts let me know . Some Navaras and 720 trucks used the same front caliper . Rears , use DR disks and fixed section of DR calipers .
Supposedly R32 RB20 mounts bolt RB30 onto MR30 cross member . Some have used the R32 brake master and booster to get clearence for the back of the twin cam inlet manifold , don't know with single cam inlet . I suspect the Z18 Turbo Bluebird booster will bolt into R30 and use the std master cyl . Lucky I've got one .
Will need RB radiator , R30 ones truly jurasic .
Power steer pump , best to use DR30 if you can make it fit right pressure for power steering BOX .
RB's used late style RB71 gearboxes , longer/stronger/different shift mechanism . VL NA manual box virtually identical to R32 RB20DET , different speedo gears for 3.45 rear gears compared to 4.1/4.375 .
Out of time Chow A .
On the brake front, I'm in the process of developing an upgrade using early Z31 hub / rotor / caliper. As far as I can see at the moment, the hub / rotor are a straight replacement for the R30 unit. The only real mod is to have the mounting holes in the caliper plugged and re-drilled at 90mm centres (currently 100mm centres).
Engine-wise for this one is the L20ET + Wolf3D. In future, I've got a RB20DET sitting in the garage that I can't seem to get rid of, so may as well bolt it into a R30 sedan.
4-speed auto: No problem, fit an RB bellhousing & you're done.
Power steering: From memory the R30 uses the same line pressures as the R31, so as long as you use a Skyline donor engine, you should be right (not that you'd even consider using an engine with 'Holden' embossed on the rocker cover!)
Please excuse the persistant questions but how much dose a low mileage RB30 cost these days? and what model Skyline dose it come from?
you should look at the local paper for early r31 TI's you colud pick one up for $500 or less unresitered, use everything from it, engine, ECU, loom, gearbox, brakes, struts, brake booster, master cylinder, all the things you'll need will be there.....using all that stuff from the r31 will be a lot easier on compliance too..
anyone know who the owner of the R30 sedan with the RB30 in it has a custom inlet manifold as stock wouldnt allow for the hood to close
also thank you to those who have had there say or oppinion, especially steveL
but i need to stress that i am not after info that is not correct or accurate as i have no time or money for, should's, maybe's, most likely's this that and the other. All im after is sum1 that has done this b4 or KNOWS! there shit.
cant stress it enough!
thanx again
Ivan
thanx again
Ivan
the rb20det fits (using 8-10mm spacers) with only the BOV touching that heat retardent stuff under the bonnet, so if you can find a height comparison that might help....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
